how to click the point you created by used divide measure command?
Hi guys here is my new question.
I just learn how to use the divide and measure command , and also I knew how to change the point style.
But after I used the divide command to split my object into 5 parties.
I can not click the point I created.
For a instance I have a 10 meters line and I used the divide command to divide it into 5 parties, and so I have 4 points.But if i want to draw some thing on the new point my mouse could not click it.
I cant do what the guy did in the video. when I move my mouse on those points I created I could not connect a line on the point like the guy did.
Do I miss something or I should set up something?
Set your osnap (object snaps) to snap to NODE.
Also, "shift", "right-click", "d" is a short-cut for the node osnap.
Very good point, and easier than typing NOD.
