Please Any one help me to create default plot layout settings using .Net.
(C# or Vb)
Layout Name should be changed from Layout1 to TCC
Plotter of layout : " DWG To Pdf.pc3"
Paper Size o: ISO A4(297.00*210MM)
Plot Type : Extends
Centre the Plot
Fit To paper
monochrome.ctb
  • 2 weeks later...
You could just create a template with that layout on it and use a macro to import that layout from the template to whatever drawing your on then plot it with that layout. That's what I did and its fairly simple.
^C^psetupin;H:/Ian'sAutocad/PRINT.dwg;Cards,PDF,PLOT;save;
This is the one that I use to import my layouts to the drawing I'm on. If your willing to give it a try I'll be willing to help you with it if needed. If not I'll do my best to help you out with .Net.
By Creating Macro and importing template requires bit manual work.. I want to create a dll ( in C# or VB) which will load automatically when Acad is started and by simply calling a function written in dll would set requirements mentioned above.
Thanking in Adavance
It's only the click of a button nothing too "manual" about it. :)
(C# or Vb)
FWIW - You may find this to be of some use... The .NET source-code (C#) is at the bottom of the linked post.
Cheers
