how to transform 2D drawing into 3D Spiral Bevel Gear?
Hello!
I have the attached drawing of spiral bevel gears;
MBSG2-2040L.dwg
it has been taken from this site
http://www.qtcgears.com/KHK/newgears/KHK206.html
how do I transform it into a 3d structure from that 2d drawing?
is all the needed information comprised in it?
I can not figure out the shape of the teeth.
There is also a 3d version of the gears for autodesk inventor; is there a way I could transform that into an autocad 2011 compatible version (I don't know much about autodesk inventor ).
Thank you !
there is also a .dxf version which shows an autocad drawing but it is still 2d and I cannot upload it as it is larger than the permitted size
Inventor can be used to save as a dwg 3d solid.
Do you have Inventor? If so, what version (in later versions it is Save Copy as type *.dwg). In earlier versions there was a Save as DWG solids I think under Tools or Manage, but don't remember exactly where. Another option in Inventor would be to Save Copy as Type ACIS (*.sat) and then use the acisin command in AutoCAD.
save as/Autocad 2010 file
worked perfectly !
Thank you very much, again, JD Mather !
I wonder why I did not think of this...
