neophoible Posted July 26, 2013 Share Posted July 26, 2013 The standard and custom scale headings in properties are only available when you highlight paperspace viewports, they won't show in model space viewports, or when a paperspace viewport is activated.I'm wondering if the OP overlooked this answer from another LT user. I don't see where he responded to it. Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 abraCADabra, I click on vp scale box with an arrow and it maximizes the viewport. Does not reveal Standard scale/Custom for scale selection. Quote Link to comment Share on other sites More sharing options...
Fire_col Posted July 26, 2013 Share Posted July 26, 2013 Walter. Just post your file for us to see, otherwise we're not going to be able to help you! Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 JD Mather, This is exactly what I am searching for..... But yet, you still ignore the information that I'm searching for to help you - the actual file. If you don't know how to attach the *.dwg file here - ask. While I am at it. Did you reboot the computer and this problem persists? Does this problem occur with any new file or just this one on particular? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 ....box with an arrow and it maximizes the viewport. .... The tool on the left is not the same as the tool on the right. The tool on the left Maximizes/Minimizes your viewport. The tool on the right ONLY appears if you select a viewport boundary. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 Boundary not selected. Viewport Boundary selected. Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 JD Mather, Sorry, I am trying to the best of my knowledge to answer each and everyone's question. I don't know how to attach the file. I did reboot the computer and the problem persists. The problem is with all of my (present and past) files. Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 JD Mather, My screen shows he tool on the left but does not show the tool on the right. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 http://www.cadtutor.net/forum/faq.php?faq=vb3_reading_posting#faq_vb3_attachments Are you sure you are in Paperspace Layout (bottom left corner indicates). Are you sure the viewport boundary is on a visible layer and not locked? I'm guessing the book might have had you Lock the viewport. Hmmm, well I just checked and the scale should appear even if the boundary is locked - as long as you have the boundary selected. But if you select that Maximize there is no way to select the viewport boundary - so click again for Minimize. Are you sure you have selected the viewport boundary? (also - if you double click inside the viewport, but I recommend that you don't do this until you have more experience to realize what this actually does) Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 JD Mather, I am in Paperspace; viewport boundary is not locked; I am certain I have selected the viewport boundary. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 Without a file, I give up..... Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 How do I send a file? Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 JD - Boundary not selected appears as you show it including the status bar below. Boundary when selected appears as you show it but the status bar below does not change as it indicates in your response Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 How do I send a file? Reply Select Go Advanced lower right corner. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 Click on paperclip to attach file and follow on-screen prompts. Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 26, 2013 Author Share Posted July 26, 2013 I attach drawing sheet A101 for 1121 Leonard project. 1121 Leonard A101.dwg Quote Link to comment Share on other sites More sharing options...
eyde Posted July 26, 2013 Share Posted July 26, 2013 Right click in the gray area of the right bottom of screen and select annotation scale. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 26, 2013 Share Posted July 26, 2013 I tried what eyde suggested and don't see how that solves the problem (post screen shot). Walter, Type QP and hit Enter on your keyboard. Click on the viewport boundary and then hit Enter on your keyboard. A QuickProperties window should pop up. What does the first line say? Quote Link to comment Share on other sites More sharing options...
WalterCarlson Posted July 27, 2013 Author Share Posted July 27, 2013 JD - QuickProperties window does not show. No changes in the screen Quote Link to comment Share on other sites More sharing options...
nestly Posted July 27, 2013 Share Posted July 27, 2013 @ All Please take note that the OP is using AutoCAD2006. Annotative Scaling was not introduced until 2008, so there is no Scale list box in the lower right corner. Similarly, QuickProperties were not introduced until 2009. @ Walter I have created a video demo using 2005, (I never used 2006LT) so I hope it's similar to what you have. Please view the video and if you still can't see a "Custom" scale property, take a screen shot of your desktop, as described at the end of the video, and post it here using the method described by JDMather in post #36 above. Demo --> Quote Link to comment Share on other sites More sharing options...
