Autopublish producing PDFs that won't print.
Using the autopublish command, I'm getting PDF files that display just fine on my monitor, but then when I try to print I get this series of error messages:
"The document could not be printed."
"There were no pages selected to print."
"A drawing error occurred."
But the most frustrating thing is that it only happens for some .dwg files, not all. It seems that the larger they are and the more pages involved, the more likely they are to produce this error. Any ideas?
EDIT: I just went through and tried to print page by page. It turns out of the 22 pages, the only two that won't print and give the errors above have no viewports and are just two large tables filled with text. Is there anything I can do to these tables to make the pages print?
Edited by jjatho
Please download Autodesk DWG Trueview or a third party software (such as Any DWG to PDF) to output the PDF file, do you have encountered the same error?
