ALLI Posted November 21, 2008 Posted November 21, 2008 Is there a way in AutoCAD 2009 to add a prefix to all layer names. IE: to change all layers from build, sewer, water to wae_build, wae_sewer, wae_water by adding wae_ to the front of all layer names. I hope this makes sense. Cheers Alli Quote
Strix Posted November 21, 2008 Posted November 21, 2008 if you have a rummage about in the lisp section, you may find somebody has written some code to do that Quote
ALLI Posted November 21, 2008 Author Posted November 21, 2008 Nope, I just looked there, there is one for mergeing two layers, but not to add a prefix. Quote
rkent Posted November 21, 2008 Posted November 21, 2008 Is there a way in AutoCAD 2009 to add a prefix to all layer names. IE: to change all layers from build, sewer, water to wae_build, wae_sewer, wae_water by adding wae_ to the front of all layer names. I hope this makes sense. Cheers Alli use the rename command, layers, *, wae_* Quote
ALLI Posted November 21, 2008 Author Posted November 21, 2008 cool, thanks, I knew therre was a simiple solution to it. Quote
