samifox Posted July 27, 2013 Posted July 27, 2013 Hi Can someone please post a simple code showing how to access a entries in list with in a list? Thanks Quote
Lee Mac Posted July 27, 2013 Posted July 27, 2013 @Moderator: Please rename thread to 'N[highlight]e[/highlight]sted List' so that it can be found in future. @samifox: Please provide an example of the list in question and the items to be retrieved. Quote
samifox Posted July 27, 2013 Author Posted July 27, 2013 Ok 2 things the best way to retrive B1 and...let say i want to boolean test if C2 exist in any of the sublist (setq lst (list (list 'A1 'A2 )(list 'B1 'B2) (list 'C1 'C2))) Quote
Lee Mac Posted July 27, 2013 Posted July 27, 2013 best way to retrive B1 _$ (setq lst '((a1 a2) (b1 b2) (c1 c2))) ((A1 A2) (B1 B2) (C1 C2)) _$ (car (assoc 'b1 lst)) ;; Position unknown B1 _$ (car (nth 1 lst)) ;; Position known B1 let say i want to boolean test if C2 exist in any of the sublist _$ (setq lst '((a1 a2) (b1 b2) (c1 c2))) ((A1 A2) (B1 B2) (C1 C2)) _$ (vl-some '(lambda ( x ) (member 'c2 x)) lst) (C2) Quote
samifox Posted July 27, 2013 Author Posted July 27, 2013 in the help reference for the vl-some() there is an example i dont fully undertand The following example checks whether nlst (a number list) has equal elements in sequence: $ (setq nlst (list 0 2 pi pi 4)) (0 2 3.14159 3.14159 4) _$ (vl-some '= nlst (cdr nlst)) T for my sense it look as following, vl-some retrive the first element in the ntls list (0) and compare it against the first element in (cdr ntls) (2) list , if the test is nil, the next element in (cdr(nlst)) (3) is being compared to the first element of ntls. if all elements in (cdr(ntls)) list been evaluated , vl some get the next element of the ntls list all of this loops until a non-nil value found is that true ? Quote
Lee Mac Posted July 27, 2013 Posted July 27, 2013 $ ([color=blue]setq[/color] nlst ([color=blue]list [/color]0 2 [color=blue]pi[/color] [color=blue]pi[/color] 4)) (0 2 3.14159 3.14159 4) _$ ([color=blue]vl-some[/color] '[color=blue]=[/color] nlst ([color=blue]cdr[/color] nlst)) [color=blue]T[/color] Here is the evaluation sequence: ([color=blue]vl-some[/color] '[color=blue]=[/color] nlst ([color=blue]cdr[/color] nlst)) --> ([color=blue]vl-some[/color] '[color=blue]=[/color] '(0 2 [color=blue]pi pi [/color]4) '(2 [color=blue]pi pi [/color]4)) ([color=blue]=[/color] 0 2 ) => [color=blue]nil[/color] ([color=blue]=[/color] 2 [color=blue]pi[/color]) => [color=blue]nil[/color] ([color=blue]=[/color] [color=blue]pi[/color] [color=blue]pi[/color]) => [color=blue]T[/color] [color=green];; cease evaluation[/color] If all elements were to be processed: _$ ([color=blue]vl-some[/color] '([color=blue]lambda[/color] ( a b ) ([color=blue]print [/color]a) ([color=blue]princ [/color]b) [color=blue]nil[/color]) nlst ([color=blue]cdr [/color]nlst)) 0 2 2 3.14159 3.14159 3.14159 3.14159 4 [color=blue]nil[/color] Hence, for a general list: ([color=blue]vl-some[/color] '([color=blue]predicate-function[/color] ( arg-1 ... arg-n )) [color=red]<list-1>[/color] [color=magenta]<list-2>[/color] ... [color=purple]<list-n>[/color]) ([color=blue]vl-some[/color] '([color=blue]predicate-function[/color] ( arg-1 ... arg-n )) [color=red]'(a1 a2 ... aN1)[/color] [color=magenta]'(b1 b2 ... bN2)[/color] ... [color=purple]'(z1 z2 ... zNn)[/color]) ([color=blue]predicate-function[/color] [color=red]a1[/color] [color=magenta]b1[/color] ... [color=purple]z1[/color]) ([color=blue]predicate-function[/color] [color=red]a2[/color] [color=magenta]b2[/color] ... [color=purple]z2[/color]) ... ([color=blue]predicate-function[/color] [color=red]aN1[/color] [color=magenta]bN2[/color] ... [color=purple]zNn[/color]) [color=green];; until min(N1,N2,...,Nn) or predicate-function returns non-nil. [/color] Quote
samifox Posted July 28, 2013 Author Posted July 28, 2013 Thanks LEE ive tried to write a function that take a list of values and search for a match in a nasted list i belive i could do it with lots of code with 2 whiles but im sure you have a better way to do it with maocar and lambda (setq suspect '(b1 c2) (setq lst '((a1 a2) (b1 b2) (c1 c2))) ;_1. get element x in suspect list ;_2. search for its occurance in all sublist of lst ;_3. if it were found ; 4. _print and exit ;_5. if it werent found ;_6. start over again with the next elemt in the suspect list Quote
samifox Posted July 28, 2013 Author Posted July 28, 2013 hi again this is what i could write by myself. i get bad argument error (setq suspect '(b1 c2)) (setq lst '((a1 a2) (b1 b2) (c1 c2))) (if (equal (vl-some '(lambda ( x ) (vl-some '(lambda (y) (member x y))lst))suspect) nil) (princ "NO Match") (princ "Yes....the suspect has been matched") ) Quote
Lee Mac Posted July 29, 2013 Posted July 29, 2013 Your code looks correct to me, though, I would reverse the if statement: (setq itm '(a3 z1 b1 c2) lst '((a1 a2) (b1 b2) (c1 c2)) ) (if (vl-some '(lambda ( x ) (vl-some '(lambda ( y ) (member x y)) lst)) itm) (princ "\nMatch found.") (princ "\nNo Match.") ) Quote
samifox Posted July 29, 2013 Author Posted July 29, 2013 hay LEE i was thinking [ if ] expects only T or nil..now your are assing it a non-nil value how come? Quote
Lee Mac Posted July 29, 2013 Posted July 29, 2013 I was thinking [ if ] expects only T or nil..now your are assing it a non-nil value In AutoLISP, any non-nil value is considered true. Quote
samifox Posted July 29, 2013 Author Posted July 29, 2013 trying to write the evaluation of this but get an error, any idea way? (listsMatcher '(a2 a5) '((a1 a2) (b1 b2) (c1 c2))) (defun listsMatcher (itm lst) (setq x 0 y 0) (while (< y (length y)) (while(< x (length x)) (if (member (nth y itm) (nth x lst)) (princ "\nMatch found.") (progn (princ "\nNo Match.") (setq x (1+ x)) ) ) ) (setq y (1+ y)) ) ) Quote
samifox Posted July 29, 2013 Author Posted July 29, 2013 hay this is what i manag to write, lord...how many lines of code is save with mapcar ad lambda ;;;******************************************************************;;; ;;;--------------------------------------------------------------------; ;;; Function: listsMatcher ; ;;;--------------------------------------------------------------------; ;;; Description: compares lists for the same occurances. first list ; ;;; is 1 level deep list while the second is 2 level deep; ;;; Argument : itm - 1 level deep list ; ;;; : lst - 2 level deep list ; ;;; Return : T if at least one match found, nil if none ; ;;;--------------------------------------------------------------------; (setq itm '(b1 c3) lst '((a1 a2) (b1 b2) (c1 c2)) ) (listsMatcher itm lst) (defun listsMatcher (itm lst) (if (vl-some '(lambda ( x ) (vl-some '(lambda ( y ) (member x y)) lst)) itm) T nil ) ) (defun listsMatcher_EVAL (itm lst/ flag) (setq x 0 y 0 flag nil) (while (< y (length itm)) (while(< x (length lst)) (if (member (nth y itm) (nth x lst)) (progn (setq x 10 y 10) (setq flag T) ) (progn (setq x (1+ x)) (setq flag nil) ) ) ) (setq y (1+ y)) (setq x 0) ) flag ) 2 things about the evaluation, i use (setq x 10 y 10) when a match is found in order to quite, is that right thing to do? i use flag to keep the boolean answer, is that right thing to do? Thanks Shay Quote
Lee Mac Posted July 30, 2013 Posted July 30, 2013 Since any non-nil value in AutoLISP is considered true, this: (defun listsMatcher (itm lst) (if (vl-some '(lambda ( x ) (vl-some '(lambda ( y ) (member x y)) lst)) itm) T nil ) ) Can become simply: (defun listsMatcher ( itm lst ) (vl-some '(lambda ( x ) (vl-some '(lambda ( y ) (member x y)) lst)) itm) ) i use (setq x 10 y 10) when a match is found in order to quite, is that right thing to do? If you are intending this to be a generic function, you cannot guarantee that the length of the supplied list will not exceed 10 items. i use flag to keep the boolean answer, is that right thing to do? If a boolean return is specifically required, however, as stated above, this is not necessary since any non-nil value in AutoLISP is considered true. Consider perhaps: (defun listsmatcher2 ( itm lst / rtn x y ) (while (and (null rtn) (setq x (car itm))) (setq tmp lst) (while (and (null rtn) (setq y (car tmp))) (setq rtn (member x y) tmp (cdr tmp) ) ) (setq itm (cdr itm)) ) rtn ) Or, recursively: (defun listsmatcher3 ( itm lst ) ( (lambda ( recurse ) (recurse itm lst lst)) (lambda ( itm tmp lst ) (cond ( (null itm) nil) ( (null lst) (recurse (cdr itm) tmp tmp)) ( (member (car itm) (car lst))) ( (recurse itm tmp (cdr lst))) ) ) ) ) Quote
samifox Posted July 30, 2013 Author Posted July 30, 2013 If you are intending this to be a generic function, you cannot guarantee that the length of the supplied list will not exceed 10 items. how can i guarantee it? Quote
Lee Mac Posted July 30, 2013 Posted July 30, 2013 how can i guarantee it? (if (< (length lst) 10) ... Quote
samifox Posted August 1, 2013 Author Posted August 1, 2013 (if (< (length lst) 10) ... and what if not? Quote
Lee Mac Posted August 1, 2013 Posted August 1, 2013 and what if not? I don't understand your question. Should the function return nil if the list contains 10 or more items? Why the restriction to 10 items? Quote
PotGuy Posted August 1, 2013 Posted August 1, 2013 and what if not? Me no comprendé. Too ambiguous. Quote
Bhull1985 Posted February 27, 2014 Posted February 27, 2014 This means that the condition will be satisfied as long as the length of lst is less than 10. If lst is less than ten, do the THEN, if not do the ELSE, of the (if) statement. If the length of lst is greater than or equal to ten then you'd simply write the conditional like (if (>= (length lst) 10) ... );if Quote
