Al H Posted July 30, 2013 Posted July 30, 2013 i am trying to recall how to use the above mentioned function to plot suveyed points into CAD and it is wrecking my head:ouch: i can get one point on but to add multiple points is beyond me at the moment Quote
Murph_map Posted July 30, 2013 Posted July 30, 2013 I have used the "Muliple" command along with the "Point" command and copy/paste to the command line the csv file. Quote
Mike_Taylor Posted July 31, 2013 Posted July 31, 2013 I have a custom command I had made in Excel at home for listing names in photos that include a space and comma. It could very easily be modified to remove the space and have just the comma in it making it ideal for exporting to a script. I will post it when i get home for you to take a look at. Quote
ayethzerothree Posted September 26, 2013 Posted September 26, 2013 excel: sample : east value = 10000 north value = 200000 command : concatenate click east value then (,) click north value [ be sure no space) result = 10000,20000 do it for all your data that you want to paste on your drawing sample result = 10000,20000 20000,40000 30000,60000 . . . . till the last value then copy the result on the drawing command line type polyline or pl only click 1 point on the screen then paste on the command line the value you have copy from excel. and thats it. . . hope it helps. . . have a nice day Quote
mdbdesign Posted September 26, 2013 Posted September 26, 2013 If you know, how to use macro codes in Excel, it will be perfect for you. Don't remember who write it for me (must be one of Excel forum) This macro combine two column into one with space between merged items. Is very easy to replace space with one you need (, . ; : ' "+-*/) using Find and Replace One thing: THERE IS NO UNDO FOR THIS MACRO, save file before execute. Sub ColumnsToMerge() Dim Rng As Range Dim Col_1 As Long, Col_2 As Long Set Rng = Selection Col_1 = Rng.Column Col_2 = Rng.Column + Rng.Columns.Count - 1 MergeTwoColumns Col_1, Col_2 Set Rng = Nothing End Sub Sub MergeTwoColumns(strCol_1 As Long, strCol_2 As Long) Dim LastRow As Long, RowNo As Long LastRow = Cells(Rows.Count, strCol_1).End(xlUp).Row For RowNo = 1 To LastRow Cells(RowNo, strCol_1) = Cells(RowNo, strCol_1) & Space(1) & Cells(RowNo, strCol_2) Cells(RowNo, strCol_2) = "" Columns(1).AutoFit Next End Sub BE CAREFUL WHEN WORKING WITH MACRO Quote
mdbdesign Posted September 26, 2013 Posted September 26, 2013 Code modify to use comma between merged items: Sub ColumnsToMerge() Dim Rng As Range Dim Col_1 As Long, Col_2 As Long Set Rng = Selection Col_1 = Rng.Column Col_2 = Rng.Column + Rng.Columns.Count - 1 MergeTwoColumns Col_1, Col_2 Set Rng = Nothing End Sub Sub MergeTwoColumns(strCol_1 As Long, strCol_2 As Long) Dim LastRow As Long, RowNo As Long LastRow = Cells(Rows.Count, strCol_1).End(xlUp).Row For RowNo = 1 To LastRow Cells(RowNo, strCol_1) = Cells(RowNo, strCol_1) & "[color=red],[/color]" & Cells(RowNo, strCol_2) Cells(RowNo, strCol_2) = "" Columns(1).AutoFit Next End Sub Replace red colored symbol to one suit you if needed. Quote
BIGAL Posted September 27, 2013 Posted September 27, 2013 concatenate function in excel Go to help for example A1=1000 B1 =2000 but =concatenate(A1,",",B1) note the "," is a comma in the string required A1,B1 would give 10002000 Quote
mdbdesign Posted September 27, 2013 Posted September 27, 2013 The only inconvenience of this concatenate function is, that you req'd additional column to do it, one sometime lack of. Quote
WilliamClarke123 Posted October 4, 2013 Posted October 4, 2013 Thanks Bigal. Your concatenate function works and it really helped me out. Quote
