vertical horizons Posted July 30, 2013 Posted July 30, 2013 Is there a way to place a watermark on an .IDW? (We are running INVENTOR 2013.) Quote
kpyoung333 Posted August 2, 2013 Posted August 2, 2013 As far as I have read there is no actual watermark feature for Inventor. A work around would be to create an image with a high level of opacity in photoshop. Right click the title block area, edit definition, insert image, and SEND BACKWARD to go behind any block info. Save changes and back at the paper space this will put the image behind your drawing dimensions. Not sure if this is what you were looking for, but it's what I use to put our logo behind drawings and makes it harder to just screen capture drawings. Quote
