ewibolo Posted July 30, 2013 Posted July 30, 2013 Hi and thanks in advance for any help. Let me explain the circumstances first. I have a 3mi roadway drawn that's split into 12 corridors with 1 alignment. I have section lines drawn every 100ft. I have the cross sections already drawn (create multiple views). All of this is in the same file. I would like to adjust the daylight from 1:6 to 1:4 on each side, which I can do through the toolspace prospector tab. There's one problem, it doesn't reflect on the cross sections that are already cut. Do I have to re-"create multiple views", or is there a way to update what's already drawn? Thanks, Eric Quote
Organic Posted July 31, 2013 Posted July 31, 2013 You should be able to update them. First make a copy of the file incase something goes wrong etc. Then edit the subassemblies to change the daylighting as desired. Then you need to rebuild the corridors to see the reflected change in the applied assemblies (right click Corridors in the prospector and go Rebuild All) and all cross sections should then update accordingly. You'll obviously need to rebuild/refresh your design surfaces also (right click on them in Prospector and go Rebuild). Quote
