I was able to convert single line text to multilingual text in 2006 using express tools. Is there a way to do the same for 2014 LT? Are there express tools that can be downloaded for LT?
I meant multi line text. Not multilingual
  • 2 weeks later...
So there is no way to convert single line text to multiline text using LT??
Probably via a diesel macro. You'd have to do an Internet search to see if such a macro is available. You might check the website for LT Unlimited.
  • 2 weeks later...
sorry i'm just occasional cad user & i use txt2mtxt command on 2010 version, no idea about LT.pls disregard if not related.
  • 4 months later...
It can be done like this. Double click the text you want to convert, and when it is in editing mode copy the text to clipboard. Then start the Mtext command and paste it into the text box. You may have to do this for every line of text.
Hope it helps.
