Hello,
Im new to lisp and trying to make a lisp that frezzes nd changes colour on some xref-layers.
This is the code, of course not working ... do I miss something out?
(defun c:kflager ()
 (setq xref_klager (*|K*))
 (setq xref_fklager (4K*|K005,4K*|K301-0))
 (command ".layer" "C" 151 "xref_klager" "" "")
 (command ".layer" "F" "xref_fklager" "" "")
Thanx in advance!
best regards
/Artur:)
You can't make a variable of the layers as you have tried
try this
(defun c:kflager ()
(command ".layer" "c" "151" "*|K*" "")
(command ".layer" "f" "4k*|K005,4K*|K301-0" "")
Ok thanx ...
If I recall right I think I previously some month ago managed to do it with setq... If I find it I will post it here.. :)
Thanx
You were close.
(defun c:kflager (/ xref_klager xref_fklager)
 (setq xref_klager "*|K*")
 (setq xref_fklager "4K*|K005,4K*|K301-0")
 (command ".layer" "C" 151 xref_klager "" "")
 (command ".layer" "F" xref_fklager "" "")
