Jessica28 Posted August 1, 2013 Posted August 1, 2013 We are running autocad Mep 2013...I have a lisp routine on my computer that allows me to edit multiple lines of text by just hitting enter and it moves to the next line...But I tried to install this on a new co-workers machine and it doesn't seem to be working...The error message she gets is "no function definition ACET-ERROR-INIT".........What could be causing this?....The lisp routine I was using is as follows.....And is there maybe an easier way we could be doing this? Thanks, Jess ;; DESCRIPTION ;; The TEDIT command provides a single command for editing all ;; forms of annotation objects. ;; ;; ---------------------------------------------------------------- (defun C:TEDIT (/ noll filter ss idx ename elist kind) ;; remove objects on locked layers from ss (defun noll (ss / i d ename) (setq i 0 d 0 ) (while (and ss (setq ename (ssname ss i)) ) (if (acet-layer-locked (cdr (assoc 8 (entget ename)))) (progn (ssdel ename ss) (setq d (1+ d)) ) (setq i (1+ i)) ) ) (if (/= 0 d) (princ (acet-str-format "%1 %2 on a locked layer.\n" d (if ( ) ss ) (acet-error-init '(("CMDECHO" 0) T)) ;; make object filter (setq filter (list (cons 410 (if (and (= 0 (getvar "TILEMODE")) (/= 1 (getvar "CVPORT")) ) "Model" (getvar "CTAB") ) ) '(-4 . " '(0 . "TEXT,MTEXT,RTEXT,ARCALIGNEDTEXT,DIMENSION,ATTDEF") '(-4 . " '(0 . "INSERT") '(66 . 1) '(-4 . "AND>") '(-4 . "OR>") ) ) ;; pick objects (if (not (and (= 1 (logand 1 (getvar "PICKFIRST"))) (setq ss (noll (ssget "_I" filter))) ) ) (setq ss (ssget "_:L" filter)) ) ;; process ss (if ss (progn (setq idx -1) (acet-ui-progress "Editing:" (sslength ss)) (sssetfirst) (redraw) (while (setq ename (ssname ss (setq idx (1+ idx)))) (redraw ename 3) (redraw) (setq elist (entget ename) kind (cdr (assoc 0 elist)) ) (cond ((or (= kind "TEXT") (= kind "MTEXT") (= kind "DIMENSION") (= kind "ATTDEF") ) (command "_.DDEDIT" ename "") ) ((= kind "INSERT") (command "_.DDATTE" ename) ) ((= kind "ARCALIGNEDTEXT") (command "_.ARCTEXT" ename) ) ((= kind "RTEXT") (if (or (= 'USUBR AcetRText:edit) (load "rtext" nil)) (AcetRText:edit elist) (princ "TEDIT: Cannot edit RTEXT objects.\n") ) ) ) (entupd ename) (redraw ename 4) (acet-ui-progress -1) ) (acet-ui-progress) (sssetfirst nil ss) ) ) (acet-error-restore) (princ) ) (acet-autoload2 '("Rtext.lsp" (AcetRText:edit ent))) (princ) Quote
ReMark Posted August 2, 2013 Posted August 2, 2013 We'll give this a *bump* and see if it attracts any interest. I should warn you that there are code posting guidelines that you may be asked to follow in the future. Good luck. Quote
SLW210 Posted August 2, 2013 Posted August 2, 2013 In the very near future. Please read the Code posting guidelines and edit your post to include the Code in Code Tags. I also have moved your thread to the AutoLISP, Visual LISP & DCL forum. Quote
Tharwat Posted August 2, 2013 Posted August 2, 2013 ...The error message she gets is "no function definition ACET-ERROR-INIT".........What could be causing this?....The lisp routine I was using is as follows.....And is there maybe an easier way we could be doing this? Thanks, Jess It throw an error because your co-worker does not have the Express Tools installed on her machine . Quote
Jessica28 Posted August 5, 2013 Author Posted August 5, 2013 I'm sorry about the code posting...I'll make sure to look at the guidelines...I had a feeing I was doing something wrong. As for my post..I guess I screwed that up too.....I didn't realize it now works with the express tools.....That lisp routine was really old and we shouldn't be using it anymore anyways.... Quote
