SamIreland
Hi there,
I want to plot 100+ drawings to PDF's and was wondering if there is a way to change the base file location it saves, to a location I can choose? I am currently using the PDF to DWG.pc3 file in a plotting script. Is there also a way to get rid of the PDF viewer when the script is running?
Thanks :D
Share this post
Link to post
RobDraw
AutoCAD's publisher has those options and more.
Share this post
Link to post
Pablo Ferral
Use the publish command or publish via the sheet set manager.
Share this post
Link to post
rkmcswain
Highly recommend publishing through the SSM.
Share this post
Link to post
SamIreland
Is there a way to implement using SSM in a script? I am working for a company that uses A3 plotting scripts and they have to use DWG to PDF.pc3 setting. I am also having a problem with opening the pdf viewer on plotting, I know there is a way to change this setting in the pc3 file but it doesn't want to co-operate with the script when it is running. Any help will be greatly appreciated.
Share this post
Link to post
