creating hatch patterns??
how do i creare a hatch pattern?
i need need the pattern in the walls of the uploaded file .
any pointers to make this easier?
cheers for all the help today, im learning alot:D
Ground Floor Plan.pdf
That is a predefined hatch, look in your hatch dialog box , under the ansi tab for ANSI31, you will probably have to set the scale larger to get the spacing you have there in your drawing
cheers played with the scale and angle and got the right result. cheers mate
Use the user defined option and you can specify the angle and the spacing.
