Rudbeckia Posted November 21, 2008 Posted November 21, 2008 How do I get Cad 2009 layout to look like the older versions layout, where you have the tabs at the bottom for each sheet. I dont like the new way it has the sheets organized. Quote
ReMark Posted November 21, 2008 Posted November 21, 2008 Right click on either the modelspace or layout icons and you can change it to show the tabs instead. Quote
ReMark Posted November 21, 2008 Posted November 21, 2008 If you are using 2009 now you might want to update your profile. Quote
EMS_0525 Posted November 21, 2008 Posted November 21, 2008 bottom right of the 09 window there is a gear symbol, workspace switching, you can switch it over to classic look.... Quote
Rudbeckia Posted November 21, 2008 Author Posted November 21, 2008 thank you all very much, that switched the layout back to the tabs this is just a trail so i will just leave my profile thanks! Quote
papagyi Posted November 21, 2008 Posted November 21, 2008 Type in Cmd "options" and click "display" tab and under layout element check box for "display layout and model tabs"! Quote
