niegrau Posted August 14, 2013 Posted August 14, 2013 I like the default behavior of 3Ds Max to set random colors to each object but I often have problem with the edge colors, it happens to be very similar to the object time to time that I have difficulty marking them. how can I change the edge colors easily in the shortest way? or could I make a default color for all the edges? Quote
Cad64 Posted August 14, 2013 Posted August 14, 2013 The only way I know to do this is to set your object color to black, create the object and then apply a colored material to it. By doing this you can have a colored object with black edges. Quote
niegrau Posted August 15, 2013 Author Posted August 15, 2013 imagine doing an interior would need thousands of object creation and each time to do this, wow ! I gotta find a way. if anything, I will post here. Quote
Cad64 Posted August 16, 2013 Posted August 16, 2013 Thousands of objects? Why do you need a different color for every object in your scene? I think you're going to run out of colors. Quote
