How to increase the size of the center mark
Be there a way to increase the length of the lines in the center mark so that they do go out to at least the diameter of the circle, so that these lines can be used to trim parts of the circle?
Gotchy
Modify your dimension style. Under the Symbols and Arrows tab change the size of the center mark.
Check your dimension style settings.
Thank you !
