We are loking at Liquid cooling the new system we are going to buy.
Looking at primarily cooling he CPU and GPU and possibly the RAM block. I have found a pretty awesome externally mounted reservoir and pump assembly for the cooling.
I am not concerned about mounting a CPU cooling block, but my concern is with the GPU mounting block, I was wondering if anyone has any experience doing this before.
I just put a garden hose in one of the empty hard drive bays.
Got any pictures? :whistle:
I used a Corsair Hydro 80 on my i5-3570k (77w) running at 4.2Ghz and stays less than 95 degrees F.
When doing a lot of crunching it will go up to 125 after 3-5 min. in a stress test. But never above.
It has a small 120mm radiator and 2 fans (Push-Pull)
