redbeardcad Posted August 20, 2013 Posted August 20, 2013 I have a drawing that has several XREFs. I would like the linetype scale to show the same in differant tabs. Base xref is the building, LTscale = .5 Equip xref is all the machines etc. LTscale =.5 Pipe layout drawing has several layout tabs set to differant scales as close up of areas. LTscale =.5 for the dwg but each tab some lines look solid instead of dash or hidden. If I have a linetype with a symbol, it shows huge. i.e. -SAN-SAN-. The SAN is so big you can't read it. How do I get a consistant line in each tab? Quote
rkmcswain Posted August 20, 2013 Posted August 20, 2013 Set these to 1 MSLTSCALE PSLTSCALE Then make sure your annotative scale is set correctly in MS and each VP. Quote
BlackBox Posted August 20, 2013 Posted August 20, 2013 Set these to 1MSLTSCALE PSLTSCALE Then make sure your annotative scale is set correctly in MS and each VP. 1+ ....... Quote
redbeardcad Posted August 21, 2013 Author Posted August 21, 2013 OK, my MSLTSCALE = 1 and PSLTSCALE = 1 and each VP on a layout tab is the same scale as Annotation scale in the properties. So, is that right? It looks better. I'm still not up to par on annotation scale. Thanks so much for your help. Quote
