greengrass_888 Posted November 22, 2008 Posted November 22, 2008 when i draw a shape such as a square or circle it automacticlly snaps to the xy axis and only shows up as a line instead of the shape. also if i try to rotate an object into the z direction it will no go. my snaps are not on and this is only on my personal computer when i open the file at school it works fine. here is a picture flickr.com/photos/25745167@N02/3050294427/ Quote
fuccaro Posted November 22, 2008 Posted November 22, 2008 It draws ok but it shows you the drawing from a wrong angle. The Z axis should point to you, not upward. AutoCAD will draw by default in the XY plane. Enter PLAN in the command line and press enter twice -this should restore the "normal" state. Welcome in the forum! Quote
Tankman Posted November 22, 2008 Posted November 22, 2008 Welcome to the forums greengrass! Visit often. Fuccaro already answered your question, as always good reply from Romania! Quote
greengrass_888 Posted November 23, 2008 Author Posted November 23, 2008 i tried the plan comand but then it asks global/current ucs/ucs and i can't hit enter Quote
Cad64 Posted November 23, 2008 Posted November 23, 2008 it asks global/current ucs/ucs and i can't hit enterType C for "Current UCS" and then hit Enter. Quote
greengrass_888 Posted November 23, 2008 Author Posted November 23, 2008 hey guys thanks for the help so far. But the plan command did not work. i uploaded another photo this might explain it better. thanks flickr.com/photos/25745167@N02/3051943150/ Quote
Cad64 Posted November 23, 2008 Posted November 23, 2008 Can you upload the drawing here? If you don't know how to do this, see here: http://www.cadtutor.net/forum/showthread.php?t=8863 Quote
greengrass_888 Posted November 23, 2008 Author Posted November 23, 2008 hey everyone, once again thanks for the help. I tried to upload the file but it was to big, i tried to zip it and it was still to big. i have found a solution though. i have and old version of the drawing and it doesn't have the same problem so i will just have to use it. Quote
fuccaro Posted November 23, 2008 Posted November 23, 2008 My opinion is the same: the Z axis should point to you, not upward. The square is showed as a line because you see it from profile. Also the cylinder spins because you rotate it around the OZ, wich is paralell with its own axis. If for some reasons PLAN can't set the orientation, try to do it yourself with the 3DORBIT command. Rotate the image until the X axis is horizontal pointing to right and Y is vertical pointing up. An other way to fix it: Go to View>Named views, search for TOP view and set it current. But in this last case I must admit that AutoCAD2009 may have a different menu structure so maybe you can't follow me. As you can see in my profile, I still use AutoCAD2006 Quote
greengrass_888 Posted November 24, 2008 Author Posted November 24, 2008 i tried the view>named view thing and it worked! thank you very much, i really apreciate all the help Quote
