katto01 Posted August 22, 2013 Posted August 22, 2013 Hello, I am trying to get the properties of all objects in a drawing. Something like using the LIST command in a loop for all objects. Say I have 100 AcDbPolylines, and I need to extract the coordinates of the points for each of them for further calculations. Interactively I would click on a polyline at a time, click list, and copy (by hand) the coordinates of the points. I would like to use this process in VBA in a loop. I did extensively searched for an answer to this question and found nothing. Thank you Quote
BlackBox Posted August 22, 2013 Posted August 22, 2013 I'm not sure I understand fully what exactly you're trying to do. You might consider the DATAEXTRACTION Command generally, of if you need something that specifically extracts the coordinates for each entity (following your example), that can be done quite easily; just need to understand the desired output (i.e., prompting at command line, writing to CSV, etc.). More information is needed. Quote
Tyke Posted August 22, 2013 Posted August 22, 2013 Blackbox is correct, we need a bit more Information. But if I understand you correctly in VBA you need to create a selection set of all of the polylines in the drawing and the for each polyline extract the "coordinates" property of each polyline and do something (?) with them. It is a simple enough job to do but give us a bit more idea how you want to deal the coordinates of each node. In an array or a list for each polyline, in a text file or just used internally in VBA. The world is your oyster, but please crack it open, there might be a Pearl inside ;-} ps BB: today is Thursday! Quote
katto01 Posted August 22, 2013 Author Posted August 22, 2013 I have this code: ------------ code starts ---------------- Sub allonspecifiedlayer() ' This routine allows the user to select everything on screen. Then it goes through all ' of the objects one by one and puts them in a list along with the layer name. ' Need to create a form called objectsfrm and add a listbox called listbox1 to form. 'dimension these variables Dim ssetObj As AcadSelectionSet Dim sset As AcadSelectionSets Dim acadobj As AcadObject Dim objname As String Dim objlayer As String Dim I As Integer I = 0 Set sset = ThisDrawing.SelectionSets For Each ssetObj In sset If UCase(ssetObj.Name) = "TEST" Then sset.Item("TEST").Delete Exit For End If Next Set ssetObj = ThisDrawing.SelectionSets.Add("TEST") ' Add all the objects to the selection set ssetObj.Select acSelectionSetAll For Each acadobj In ssetObj 'Filter out everything on specified layer. If acadobj.Layer = "objects" Then objname = acadobj.ObjectName objlayer = acadobj.Layer Debug.Print objname, acadobj.Handle 'objectsfrm.ListBox1.AddItem objname I = I + 1 End If Next acadobj 'Show form 'objectsfrm.show End Sub ------------ code ends ------------- for each objname in the loop I wopuld like to extract all the info (especially coordinates ) and writing on an excel sheet Quote
Tyke Posted August 22, 2013 Posted August 22, 2013 You need to read up on posting code. You will get a mod in your neck for what you just posted! Quote
Tyke Posted August 22, 2013 Posted August 22, 2013 Instead of filtering all objects in the drawing you should just filter the polylines on that layer. At the moment I cannot be much more help as I am not on a machine with AutoCAD. What you want is doable. Code the following: filter all the polylines on the layer (? or all polylines in the drawing?) make your Connection to Excel for each polyline in your selection set create a loop where you write the coordinates of each node to Excel, incrementing Excel cell values for each Point enter a blank line in Excel (?) to show a new polyline is about to start when you are done close the connection to Excel Quote
SLW210 Posted August 22, 2013 Posted August 22, 2013 You need to read up on posting code. You will get a mod in your neck for what you just posted! Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote
BlackBox Posted August 22, 2013 Posted August 22, 2013 Blackbox is correct, we need a bit more Information. *Tips hat* ps BB: today is Thursday! ... But yesterday wasn't. for each objname in the loop I wopuld like to extract all the info (especially coordinates ) and writing on an excel sheet Unfortunately, you're still not providing enough information... We get that you want to export the data to Excel... As a CSV dump of all coordinates? One CSV for each polyline? We need some sort of example of the desired output in order to even begin giving you pointers in the right direction so that you can code what you're after. Cheers Quote
katto01 Posted August 22, 2013 Author Posted August 22, 2013 I apologize. let me try this: 1. I have a drawing with many different objects (polylines, lightpolylines, cubes, spheres, etc.) 2. I need to get the equivalent of the information provided by the command LIST. 3. Organize the information in a table in an excel file (not csv) in a similar way the LIST command displays it LWPOLYLINE Layer "0" Handle 1bd Closed Constant width 0.0000 area 6.8234 perimeter 10.4581 at point X= 12.0160 Y= 11.8917 Z= 0.0000 at point X= 14.7416 Y= 11.8917 Z= 0.0000 at point X= 14.7416 Y= 9.3883 Z= 0.0000 at point X= 12.0160 Y= 9.3883 Z= 0.0000 Quote
BIGAL Posted August 23, 2013 Posted August 23, 2013 This is VL code but is easily converted to VBA it uses the properties function to get the co-ords same as you can get "layer" "Color" "width etc hope it is helpfull (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy (I numb xy) ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq numb (/ (length co-ords) 2)) (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) (princ co-ordsxy) Quote
Tyke Posted August 23, 2013 Posted August 23, 2013 Or if you want it in VBA: Sub ListProps() Dim ssPolys As AcadSelectionSet Dim ssName As String Dim intCodes() As Integer Dim varValues As Variant Dim objEnt As AcadEntity Dim objLWPoly As AcadLWPolyline Dim objPoly As AcadPolyline Dim strName As String Dim strLayer As String Dim strHandle As String Dim strClosed As String Dim dblWidth As Double Dim dblArea As Double Dim dblPerim As Double Dim dblCoords() As Double On Error Resume Next ssName = "ssPolys" ' try to set the selection set Set ssPolys = ThisDrawing.SelectionSets(ssName) ' if it does not exist an error will occur - so add it If Err Then Set ssPolys = ThisDrawing.SelectionSets.Add(ssName) End If ' clear all data from selection set ssPolys.Clear ' set the filter ReDim intCodes(5): ReDim varValues(5) intCodes(0) = -4: varValues(0) = "<and" intCodes(1) = -4: varValues(1) = "<or" intCodes(2) = 0: varValues(2) = "PolyLine" intCodes(3) = 0: varValues(3) = "LwPolyLine" intCodes(4) = -4: varValues(4) = "or>" intCodes(5) = -4: varValues(5) = "and>" ssPolys.Select acSelectionSetAll, , , intCodes, varValues ' now make your connection to Excel ' now you have all the polylines in a selection set iterate it to get the properties For Each objEnt In ssPolys strClosed = "Open" If objEnt.ObjectName = "AcDbPolyline" Then strName = "Polyline2D" 'objLWPoly.ObjectName Else strName = "LWPolyline" 'objPoly.ObjectName End If ' extract the properties strName = objEnt.ObjectName strLayer = objEnt.Layer strHandle = objEnt.Handle If objEnt.Closed = True Then strClosed = "Closed" dblWidth = objEnt.ConstantWidth dblArea = objEnt.Area dblPerim = objEnt.Length dblCoords = objEnt.Coordinates ' send the above properties to Excel ' iterate through the coords array and send the coordinates to Excel Next objEnt ' close your connection to Excel End Sub Quote
katto01 Posted August 25, 2013 Author Posted August 25, 2013 Perfect, this is what I was looking for. Quote
SLW210 Posted August 25, 2013 Posted August 25, 2013 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Did you overlook this? Quote
