Create a Property Set to calculate height between center of pipe and preset elevation
Sirrojo
I think this is possible, I just need the right formula setup.
I need to generate a property set for the distance from the bottom of the floor deck above which I would like to set as a static elevation in the property set (520'-6") and use the formula to take the center of pipe calc and give me the answer so that I can use the label tag to tag all my pipe connections.
I cannot figure out how to set the elevation number in my formula.
  • 4 weeks later...
Have you figured it out yet, or do you still need a hand? See if you can use the file I sent a link to in the post, "property sets, AEC spaces and tags."
