Material size (WxLxH) auto update in iProperty
Hello everyone.
i have a request from my tool maker in machine shop and need help on this
We need the material size (W x L x H) or (Dia x L) to be automatic updated and shown on idw (title block) so that they can prepare the material easily for squaring process.
Possible to have an i-Logic or other method to enable the Inv2012Pro automatic update the (W,L,H) or (Dia,L) when saving the file and before exit ?
hi Kenny,
Very thanks for info.
Now i need to figure out how it can recalculate automatically if (let say) i extruded another 20mm from one end from original Length.
I got it!
try running this iLogic rule.
We just need to learn how to apply the message box output to parameters now!
Dim Length As Decimal = 0.0
Dim Height As Decimal = 0.0
Dim Width As Decimal = 0.0
Length = Measure.ExtentsLength
Height = Measure.ExtentsHeight
Width = Measure.ExtentsWidth
Dim SLength As String = Length.ToString()
Dim SHeight As String = Width.ToString()
Dim SWidth As String = Height.ToString()
MessageBox.Show("L = " + SLength + vbNewLine + "W = " + SWidth + vbNewLine + "H = " + SHeight , "Part Size")
Ok I figured it out 2 minutes after posting.
You will need to create 3 custom iProperties.
length
width
height
Then run this rule.
iProperties.Value("Custom", "length") = SLength
iProperties.Value("Custom", "width") = SWidth
iProperties.Value("Custom", "height") = SHeight
Hi Kenny,
Very very thanks you for the code :D
Really appreciated and i can auto insert it the idw when printing drawings.
Below is what i have changed little bit on the codes
Dim oLength As Decimal
Dim oHeight As Decimal
Dim oWidth As Decimal
oLength = Round(Measure.ExtentsLength,2)
oHeight = Round(Measure.ExtentsHeight,2)
oWidth = Round(Measure.ExtentsWidth,2)
Dim SLength As String = oLength.ToString()
Dim SHeight As String = oHeight.ToString()
Dim SWidth As String = oWidth.ToString()
iProperties.Value("Custom", "Length") = SLength
iProperties.Value("Custom", "Height") = SHeight
iProperties.Value("Custom", "Width") = SWidth
'MessageBox.Show("Length = " + SLength + vbNewLine + "Width = " + SWidth + vbNewLine + "Height = " + SHeight , "Part Size")
You're welcome, I'm glad I could help! It's not often I can actually offer a solution around here. Plus I learned a little bit about iLogic while trying to solve this.
Nice to see some iLogic code getting shared on this site and working together to get an end result;)
