VBA code to iterate thru specific block references
i cant believe i have spent as much time already as i have trying to find a solution to such a simple problem - the code i am about to post explains itself, i hope - i am trying to iterate thru the block references collection in VBA, so that i can process a set of code (the code is irrelevant as i already know how to do that part)
here's the simple code i am trying to use, and it wont even start the loop so i must have something defined wrong
please explain what part i am not comprehending
(it's all modelspace, no layoutspace)
i hope this website emails me when people reply... i've never posted here before and i'm not sure how this works
Sub PW()
 Dim blkEndcap As AcadBlockReference
 ' iterate thru a list of blocks named "fixture_block" and also have ScaleX set to 15 and ScaleY set to 5
 For Each blkEndcap In ThisDrawing.Blocks
   If blkEndcap.Name = "fixture_block" And blkEndcap.ScaleX = 15 And blkEndcap.ScaleY = 5 Then
     debug.print "found one"
   End If
 Next
End Sub
Edited by abraxus
i'm probably going to have to wait at least 24 hours for a helpful reply, arent i... damn it - i wanted to get this done tonight
It's been awhile since using VBA, but try this:
Dim AENT As AcadEntity
       For Each AENT In ThisDrawing.ModelSpace
           If TypeOf AENT Is AcadBlockReference Then
               Set blkEndcap = AENT
               If blkEndcap.Name = "fixture_block" And And blkEndcap.ScaleX = 15.0 And blkEndcap.ScaleY = 5.0  Then
               End If
           End If
       Next AENT
Though, I should mention - if the block reference in question is a dynamic block then you will have to use
AcadBlockR​eference.E​ffectiveNa​me
that helped... but i still cannot seem to reference the scale part - here's how i broke it down
Sub pw3()
               If blkEndcap.Name = "fixture_block" Then
                 If blkEndcap.ScaleX = 15# Then
                   If blkEndcap.ScaleY = 5# Then
                    Debug.Print "found one"
                   End If
                 End If
               End If
           End If
       Next AENT
End Sub
and thank you so much for at least giving me something to go on
Try:
If blkEndcap.XScaleFactor = 15# Then
OMG thank you - that worked
the documentation is horrible when trying to google things like this
thank you thank you thank you thank you thank you
You're welcome. I'm happy you are up and running.
AutoCAD used to come with a fairly good VBA reference. I think it was removed back when Autodesk planned on eliminating the VBA customization option. Look around on Autodesk.com, it may still be available for download.
oh i know they removed it from the default install, because it can be abused like any other VBA code
which leads me to another question that you probably wont be able to answer, due to the complexity of corporate network administration, but when i write VBA code for autocad on my home computer, it works just fine, but when i try to run it at work, i get a weird error (i forget what it was, but i can write it down tomorrow and explain it if you might be able to help me with that too) - i'm guessing it's related to windows 7 and maybe some network restrictions, or registry restrictions or something... all i'm doing in the code that has the problem is trying to create VBA code that sets up some dimension variables, but it's like i dont have "permission" to change those variables with VBA code... any ideas? if not, that's cool... you already helped me get past the stupid issue i was having *puts on coder hat*
in short, it errors out on this line of code
' set dimension variables
ThisDrawing.SetVariable "DIMCLRD", FDS_DIMCLRD
do i need some sort of admin permissions to set variables in "ThisDrawing"?
(it's not an error in variable declaration, because it works just fine with the same file on my home computer)
I haven't heard anything specific regarding network restriction. That particular variable is saved in the drawing, so it shouldn't even be flagged by some corporate policy concerning Registry modification on your work computer.
Unfortunately, I can't look into it in any detail as I no longer have access to a computer with VBA installed.
If you do figure out the problem, be sure to post a follow up.
