save each layer in a separate file
Guest x.bonnet
Works like a charm!! Many many thanks!
For learning purposes what does the following line do:
(LM : DXF->Variants (list (cons 8 (LM:lst->str (_LayerList doc) ","))) 'typ 'val)
I guesse here is the content in the dwg-file saved:
(if (not (zerop (vla-get-Count ss))) (vla-WBlock doc file ss))
right?
If I change the suffix "dwg" in "dxf"
setq file (getfiled "Create Output File" "" "dwg" 1))
Would I get a dxf-file as a result?
Edited by chraibi
space between : and D
Excellent, good to hear.
Creates two variants - one of integer type and one of variant type to house the data for the selection set filter.
right?
I haven't tried, but yes, that is where you would change it.
Lee
Unfortunately it does not work! I googled a little and found this hint:
write:
(setenv"DefaultFormatForSave""13")
bevor:
Look at the DefaultFormatForSave environment variable (getenv/setenv
functions)
the values are :
"48" -> dwg 2010
"36" -> dwg 2007
"24" -> dwg 2004
"12" -> dwg 2000
"8" -> dwg R14
"38" -> dwt
"37" -> dxf 2007
"25" -> dxf 2004
"13" -> dxf 2000
"1" -> dxf R12
But this fails too! :-(
Mybe another Idea?
  • 2 weeks later...
Lee Mac: I don't know why I can not send you a pm. But do you mind if I publish your code, that you helped me with, on my private homepage? Of corse with a link to yours or to the discussion here.
OU! OU! *waves hand* I know! I know! :P
You can't use the PM-system til you have 10 posts under your belt. This is to prevent spamming mostly.
Oh, and in the future, please start a new thread for each new question. I realise that this question is based on the old question, but it confuses things to have a thread form 2006 pop up again.
Hi Chraibi,
Certainly, providing all headers remain in tact :) I feel honoured to have my code feature elsewhere on the web :)
Lee
  • 1 year later...
Try to use. Look at comments!
Limitations: file sould be opened "full" (not partial). All layers should
be thawed, on, unlocked (not controlled).
Layout entities will create unexpected result - be careful!
Actually there are some ways to change code to select only model entites
But i can't do it - i've got too much job
And something else  - look how the code works
* written by kpblc 2006 Nov 23
(defun c:lay2file (/ adoc selset)
 (vl-load-com)
 (vla-startundomark
   (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
   ) ;_ end of vla-StartUndoMark
 (vlax-for ss (vla-get-selectionsets adoc)
   (if (= (vla-get-name ss) "temp")
       (vla-clear ss)
       (vla-erase ss)
       ) ;_ end of progn
     ) ;_ end of if
   ) ;_ end of vlax-for
 (setq selset (vla-add (vla-get-selectionsets adoc) "temp"))
 (vlax-for lay (vla-get-layers adoc)
   (if (and (not (vla-select
                   selset
                   acselectionsetall
                   (vlax-make-variant
                     (vlax-safearray-fill
                       (vlax-make-safearray
                         vlax-vbdouble
                         '(0 . 0)
                         ) ;_ end of vlax-make-safearray
                       ) ;_ end of vlax-safearray-fill
                     ) ;_ end of vlax-make-variant
                   (vlax-make-variant
                         vlax-vbvariant
                         '(0 . 0)
                       (list (vla-get-name lay))
                   ) ;_ end of vla-select
                 ) ;_ end of not
            (> (vla-get-count selset) 0)
            ) ;_ end of and
     (vla-wblock
       adoc
       (strcat (getvar "dwgprefix") (vla-get-name lay) ".dwg")
       selset
       ) ;_ end of vla-Wblock
     ) ;_ end of if
   (vla-clear selset)
 (vl-catch-all-apply '(lambda () (vla-delete selset)))
 (vla-endundomark adoc)
 ) ;_ end of defun
At VBA code could be more readable.
this works great....but i was hoping to have the file name as a prefix on the front of the created file before the layer name.can you please tell me where & what to input i have tried several areas but have failed :(
Here is my version:
[color=GREEN];; Layers to Drawings  -  Lee Mac  -  2011  -  www.lee-mac.com[/color]
[color=GREEN];; WBlocks objects on each layer in a drawing to separate drawing files.[/color]
([color=BLUE]defun[/color] c:lay2dwg ( [color=BLUE]/[/color] _UniqueFilename acdoc acsel fpath typevar )
   ([color=BLUE]defun[/color] _UniqueFilename ( seed [color=BLUE]/[/color] f i )
       ([color=BLUE]setq[/color] i 1)
       ([color=BLUE]if[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] f ([color=BLUE]strcat[/color] seed [color=MAROON]".dwg"[/color])))
           ([color=BLUE]while[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] f ([color=BLUE]strcat[/color] seed [color=MAROON]"("[/color] ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] i ([color=BLUE]1+[/color] i))) [color=MAROON]").dwg"[/color]))))
       f
   ([color=BLUE]defun[/color] _UniqueItem ( collection seed [color=BLUE]/[/color] i )
           ([color=BLUE]null[/color]
               ([color=BLUE]vl-catch-all-error-p[/color]
                   ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-item[/color]
                       ([color=BLUE]list[/color] collection ([color=BLUE]strcat[/color] seed ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] i ([color=BLUE]1+[/color] i)))))
       ([color=BLUE]strcat[/color] seed ([color=BLUE]itoa[/color] i))
   ([color=BLUE]setq[/color] acdoc ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
         acsel ([color=BLUE]vla-get-selectionsets[/color] acdoc)
         acsel ([color=BLUE]vla-add[/color] acsel (_UniqueItem acsel [color=MAROON]"lay2dwg"[/color]))
         fpath ([color=BLUE]strcat[/color] ([color=BLUE]getvar[/color] 'DWGPREFIX) ([color=BLUE]cadr[/color] ([color=BLUE]fnsplitl[/color] ([color=BLUE]getvar[/color] 'DWGNAME))) [color=MAROON]"_"[/color])
   ([color=BLUE]vla-clear[/color] acsel)
   ([color=BLUE]setq[/color] typevar
       ([color=BLUE]vlax-make-variant[/color]
            ([color=BLUE]vlax-safearray-fill[/color]
                ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbinteger[/color] '(0 . 1)) '(8 410)
   ([color=BLUE]vlax-for[/color] layer ([color=BLUE]vla-get-layers[/color] acdoc)
       ([color=BLUE]vla-select[/color] acsel [color=BLUE]acselectionsetall[/color] [color=BLUE]nil[/color] [color=BLUE]nil[/color] typevar
                   ([color=BLUE]vlax-make-safearray[/color] [color=BLUE]vlax-vbvariant[/color] '(0 . 1)) ([color=BLUE]list[/color] ([color=BLUE]vla-get-name[/color] layer) [color=MAROON]"Model"[/color])
       ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]vla-get-count[/color] acsel))
           ([color=BLUE]progn[/color]
               ([color=BLUE]vla-wblock[/color] acdoc (_UniqueFilename ([color=BLUE]strcat[/color] fpath ([color=BLUE]vla-get-name[/color] layer))) acsel)
   ([color=BLUE]vla-delete[/color] acsel)
   ([color=BLUE]princ[/color])
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Another alternative here.
  • 2 years later...
Hello all,
I have found the Autocad_Script.lsp to be a great help to me, but I was wondering how this could be modified to save each layer in an earlier version of AutoCAD i.e 2000 or R14.
Any assistance would be appreciated.
John
(defun c:lsave(/ actDoc layCol docName dwgName actSel fCount)
(vl-load-com)
(defun BrowseFolder (/ ShlObj Folder FldObj OutVal)
(vl-load-com)
(setq
ShlObj (vla-getInterfaceObject
"Shell.Application"
Folder(vlax-invoke-method ShlObj 'BrowseForFolder 0
"Select Folder to create files" 0)
(vlax-release-object ShlObj)
(if Folder
(setq
FldObj (vlax-get-property Folder 'Self)
OutVal (vlax-get-property FldObj 'Path)
(vlax-release-object Folder)
(vlax-release-object FldObj)
OutVal
(setq actDoc(vla-get-ActiveDocument
actSel(vla-get-ActiveSelectionSet actDoc)
layCol(vla-get-Layers actDoc)
docName(vla-get-Name actDoc)
fCount 0
); end setq
(if
(setq wntPath
(BrowseFolder))
(vlax-for lay layCol
(setq layName(vla-get-Name lay)
dwgName
(strcat wntPath "\\"
(vl-filename-base docName)
" - " layName ".dwg")
); end setq
(vla-clear actSel)(vla-erase actSel)
(vla-Select actSel acSelectionSetAll nil nil
(vlax-make-safearray vlax-vbInteger '(0 . 0))
) ; end vla-safearray-fill
(vlax-make-safearray vlax-vbvariant '(0 . 0))
(list layName)
) ; end vla-select
(if(/= 0(vla-get-Count actSel))
(vla-WBlock actDoc dwgName actSel)); end if
(setq fCount(1+ fCount))
); end vlax-for
); end progn
); end if
(princ
(strcat "\*** "
(itoa fCount)
" files were created *** "))
); end of c:lsave
Edited by anbard
wrap code
...how this could be modified to save each layer in an earlier version of AutoCAD i.e 2000 or R14...
I think it's impossible. Code uses vla-wblock function. This function can save dwg only at native format.
Thanks for relying!
If it's impossible then the other option is to open the files and saveas version required as suggested, I started this today. If there is a batch way of doing this I'm open to suggestion but limited in programming skills! Willing to learn but just need direction!
Many thanks again,
John
