if you are using mechanical 2004 there is a content library with fasteners in it. If you are using acad this will be difficult. You should search for this subject or start a new thread to get help with it. That way if someone does a search for it, it will show up for them.
I've moved this question to its own thread.
Fidani, scroll down to the "Similar Threads" at the bottom of this page and check the results, or do as Shift suggested, and use the forum's Search function. This question has been asked and answered many times.
