aGont Posted September 10, 2013 Posted September 10, 2013 I have hatches, and I need their outlines in the form of a simple polyline. I thought I could go Hatchedit > Recreate boundary. But no, when I select the option to make a polyline it gives me a spline. I did some research, and it turns out hatches can be spline- or polyline-based, so I cant get a polyline from these hatches. Also, I tried converting the resulting spline to a polyline, but I get one with a gazillion nodes, which the CNC machine doesnt like (It keeps stopping at each node) I dont quite understand the difference between a polyline made up of many small line segments (the one i got from the spline), and the one made up of curves (like you get from, say, drawing a polyline circle). How can I get the latter type of polyline from either the hatch or the spline? Thanks Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 (edited) Attach a copy of the DWG file to your next post. One possible solution for converting splines to polylines is available at the DotSoft website. Download SPL2PL.VLX and give it a try. SPL2PL.VLX converts a selection set of splines to polylines inside the drawing. http://www.dotsoft.com/freestuff.htm BTW...have you tried doing a "saveas" to R-12 DXF file format? Some CNC routers will read DXF files. Edited September 10, 2013 by ReMark Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 If neither approach above works take a look at this article. Pay particular attention to the use of the FLATTEN, OVERKILL and SPLINEDIT commands mentioned. http://cadsetterout.com/autocad-tutorials/cad-to-cam-cleaning-up-dwg-files-for-cnc/ Quote
aGont Posted September 10, 2013 Author Posted September 10, 2013 Attach a copy of the DWG file to your next post. One possible solution for converting splines to polylines is available at the DotSoft website. Download SPL2PL.VLX and give it a try. SPL2PL.VLX converts a selection set of splines to polylines inside the drawing. http://www.dotsoft.com/freestuff.htm BTW...have you tried doing a "saveas" to R-12 DXF file format? Some CNC routers will read DXF files. Thanks for the tips. Unfortunately, I already tried some of these with no luck. The SPL2PL command seems useful, but again, it only seems to split into straight segments. Here is a file that shows what I tried so far Pline to Spline.dwg Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 (edited) Why aren't you using a program to draw these shapes that can also generate the code necessary to run CNC machine? Did you try using the SPLINEDIT command? Edited September 10, 2013 by ReMark Quote
SEANT Posted September 10, 2013 Posted September 10, 2013 I Exploded the spline, Flattened, then PEDIT. Does this work any better for the CNC software? Pline to Spline_2.dwg Quote
aGont Posted September 10, 2013 Author Posted September 10, 2013 If only it were that easy. I didnt draw this (its only an excerpt from a larger graphic) and the people that drew it arent expected to know what linetypes need to be used. Its my job to translate this into something the CNC can read. I experimented a bit more and the best solution so far is to explode the spline, and then flatten the individual curves. Its not 100% accurate, but its pretty close. I was hoping for something a little simpler, and this is just another series of steps that will take some time. Honestly , I think its pretty criminal for Autodesk to not have a simple solution. Quote
aGont Posted September 10, 2013 Author Posted September 10, 2013 I Exploded the spline, Flattened, then PEDIT. Does this work any better for the CNC software? Haha, I just came up with this a few minutes ago! Thanks anyways Quote
ReMark Posted September 10, 2013 Posted September 10, 2013 Was the use of the SPLINEDIT command that gave you all the unwanted nodes? Quote
aGont Posted September 10, 2013 Author Posted September 10, 2013 Was the use of the SPLINEDIT command that gave you all the unwanted nodes? Yes. The same thing happens when I do other conversions local to autocad, such as saving as R12 Quote
rkent Posted September 10, 2013 Posted September 10, 2013 You will want to explode the shape first then do flatten. Currently it is one spline, exploding will create multiple splines, flatten will create curved plines. Quote
