htsteel Posted September 11, 2013 Posted September 11, 2013 hello everyone the image above is a piping layout with two 45 degrees elbows. i drew the side view, then the the top view now one of the 45 degrees elbow is replaced by a 90 degrees elbow. i don't how to draw this because the 90 degrees elbow rotate 45 degrees from the horizon. any methods or suggestions are helpful. thanks. Quote
JD Mather Posted September 11, 2013 Posted September 11, 2013 I like to draw circles and trim, but you could also do arcs or do fillets (with trim set off). Attach your dwg attempt here if you can't figure it out. Quote
