SaveLDD Posted September 12, 2013 Posted September 12, 2013 My other 5 computers are able to create a surface using LDD 2007, and work fine. However, I have loaded LDD 2007 on a new machine. Everything else in LDD works , ie.. creating alignments, points, parcels, etc.. But when I select the contours to build a surface I get wild coordinates and elevations, the surface status says "out of date", and the Surface statistics "No of Points" is -1. Can anyone help? Quote
Murph_map Posted September 12, 2013 Posted September 12, 2013 My other 5 computers are able to create a surface using LDD 2007, and work fine. However, I have loaded LDD 2007 on a new machine. Everything else in LDD works , ie.. creating alignments, points, parcels, etc.. But when I select the contours to build a surface I get wild coordinates and elevations, the surface status says "out of date", and the Surface statistics "No of Points" is -1. Can anyone help? What operating system on the new machine? Windows 8 ? Did you install the latest service packs as well? Quote
