satishrajdev Posted September 16, 2013 Posted September 16, 2013 What You want to do exactly??? Do you want to convert Lisp(*.lsp) file to Fast and Secure(*.fas) files? If yes then try below given code:- ;; LSP2FAS.lsp ; Scot Harris 11-29-2012 ;; Minimizes the sequence needed to create FAS files. ;; Help facility added. ;; Streamlined from original program provided by aqdam1978. (defun c:LSP2FAS-Help (/) (alert (strcat "\tLisp (LSP) to Fast and Secure (FAS) Help" "\n " "\nFile dialog begins in the current directory. " "\nIt is suggested to place and open a drawing (DWG) " "\ninside the input folder you wish to batch process. " "\n " "\nOutput file will be in the same folder as the file selected. " "\n " "\nThere is no provisional check for an existing FAS file of the same name. " )) );end LSP2FAS-Help (defun c:LSP2FAS ( / a ) (vl-load-com) (prompt " Lisp to Fast and Secure (FAS). LSP2FAS-Help available. ") (if (wcmatch (strcase (setq a (getfiled "Convert LSP File to FAS" (getvar "DWGPREFIX") "" 16))) "*.LSP") (progn (c:vlide)(vlisp-compile 'st a) (princ (strcat "\n File " (vl-string-subst ".fas" ".lsp" a) " created. ")) );progn (alert "File extension must be \".LSP\" ") );if (princ) );end LSP2FAS Quote
ReMark Posted September 16, 2013 Posted September 16, 2013 1) You can use FAS (e.g. using the vlisp-compile function). 2) You can convert it to a VLX application (an encrypted LISP file). Quote
Tharwat Posted September 16, 2013 Posted September 16, 2013 I want to protect my lisp: To protect it from what / Whom ? Does it really matter to protect that simple lisp from others ? Quote
ReMark Posted September 16, 2013 Posted September 16, 2013 Too late. I already stole it. Kidding. Why would I want to? Quote
Tharwat Posted September 16, 2013 Posted September 16, 2013 Too late. I already stole it. It was on my mind too . Kidding. Why would I want to? It is not a bad idea to protect your work when it deserves to . but not with every simple thing which would make you to look like a giant in front of the newbie Caders Quote
SLW210 Posted September 16, 2013 Posted September 16, 2013 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote
