Hi guys. I've made a grid system of 5 meters per unit and RL of each points is known to me. How do I create this grid system in AutoCad? I've seen people writing about importing survey points file into AutoCad, but how do we create one such?:unsure:
As in you've made it on paper or set it out in the field, not in AutoCad, right?
You can use the polyline (pl) tool to draw a line in the vertical direction and in the horizontal direction. Then use the offset (o) tool to offset these 5 metres. You can then put a point (po) at the intersections of the created grids.
You can import survey points into AutoCad although you need the data to come from a total station or similar.
I guess you could write out the coordinates of all your points, e.g.
0,0,100.000
5,5,101.295
0,10,102.625
etc etc to import them into AutoCad although that will take longer than drawing it.
