Structure Rim Elevations Not Adjusting to Surface
Hello,
So I noticed that 2 structures are not adjusting to the surface. I made sure that they are associated to the correct surface and that the "Automatic Adjustment" option was set to 'True.' I deleted the structures and inserted new ones, but no luck. I checked other structures and they are fine.
Notice that it says in the top line what the surface insertion elevation is, but despite the auto adjustment option set to true, it still inserts at a different elevation.
Thoughts?
N/M. I figured it out. I realized that there was not enough cover for the pipe. So it was raising the rim to meet the minimum required cover.
