NoelStalker Posted November 24, 2008 Posted November 24, 2008 Is there any automated way of aligning the insertion points of text? I once worked at a company that had a command that allowed you to select one string of text and then select multiple strings of text and make them aligned to the first string of text. Quote
lpseifert Posted November 24, 2008 Posted November 24, 2008 You could use Experess tools' Txt2mtxt, or give this a try... (defun c:test (/ ss1 sslen newxpt cnt ent ed old72 new72 old10 new10 oldxpt) (setq ss1 (ssget '((0 . "*text"))) sslen (sslength ss1) newxpt (car (getpoint "\nSelect point for alignment: ")) cnt 0 ) (repeat sslen (setq ent (ssname ss1 cnt) ed (entget ent) old72 (assoc 72 ed) new72 (cons 72 0) ed (subst new72 old72 ed) old10 (assoc 10 ed) oldxpt (cadr old10) new10 (subst newxpt oldxpt old10) ed (subst new10 old10 ed) );setq (entmod ed) (setq cnt (1+ cnt)) );repeat (princ) );defun Quote
fuccaro Posted November 24, 2008 Posted November 24, 2008 What do you mean by "aligne"? You can select some texts and in the properties window set their insertion point to have the same X value -this will align them horisontally, without to affect their vertical position. Quote
wannabe Posted November 25, 2008 Posted November 25, 2008 Our company has those commands; neat X and neat Y they are called. You choose one item of mtext and it then matches the ones you select after to have either the same X or Y coordinate. Unfortunately, I am not able to post this routine. Quote
NoelStalker Posted December 12, 2008 Author Posted December 12, 2008 lpseifert, I was not aware of txt2mtxt. Thanks! Also, your lisp routine works wonderfully. Thank you very much and have a great day. Sincerely, Noel Quote
