ILoveMadoka Posted November 24, 2008 Posted November 24, 2008 1) Can the creation of new dim styles be automated? Script? Lisp? 2) Can Dim Styles be locked such that they cannot be modified, bypassed or ignored? Ok.. so that's 4 questions... Please advise!! Thanks so much for all previous help!! Quote
Lee Mac Posted November 26, 2008 Posted November 26, 2008 1) I personally have never tried to create a dimstyle via LISP methods, but I suppose the way I would go about it is to set all the dim variables to how I would like the dim-style to be:, i.e. DIMADEC 0 Angular decimal places DIMALT Off Alternate units selected DIMALTD 4 Alternate unit decimal places DIMALTF 0.0394 Alternate unit scale factor DIMALTRND 0.0000 Alternate units rounding value DIMALTTD 4 Alternate tolerance decimal places DIMALTTZ 0 Alternate tolerance zero suppression DIMALTU 8 Alternate units DIMALTZ 0 Alternate unit zero suppression DIMAPOST Prefix and suffix for alternate text DIMASZ 3.0000 Arrow size DIMATFIT 3 Arrow and text fit DIMAUNIT 0 Angular unit format DIMAZIN 0 Angular zero supression DIMBLK ClosedFilled Arrow block name DIMBLK1 ClosedFilled First arrow block name DIMBLK2 ClosedFilled Second arrow block name DIMCEN 0.0000 Center mark size DIMCLRD 5 (blue) Dimension line and leader color DIMCLRE 5 (blue) Extension line color DIMCLRT 2 (yellow) Dimension text color DIMDEC 2 Decimal places DIMDLE 0.0000 Dimension line extension DIMDLI 2.0000 Dimension line spacing DIMDSEP . Decimal separator DIMEXE 2.0000 Extension above dimension line DIMEXO 2.0000 Extension line origin offset DIMFRAC 0 Fraction format DIMGAP 2.0000 Gap from dimension line to text DIMJUST 0 Justification of text on dimension line DIMLDRBLK ClosedFilled Leader block name DIMLFAC 1.0000 Linear unit scale factor DIMLIM Off Generate dimension limits DIMLUNIT 2 Linear unit format DIMLWD -2 Dimension line and leader lineweight DIMLWE -2 Extension line lineweight DIMPOST Prefix and suffix for dimension text DIMRND 0.0000 Rounding value DIMSAH Off Separate arrow blocks DIMSCALE 0.0000 Overall scale factor DIMSD1 Off Suppress the first dimension line DIMSD2 Off Suppress the second dimension line DIMSE1 Off Suppress the first extension line DIMSE2 Off Suppress the second extension line DIMSOXD Off Suppress outside dimension lines DIMTAD 3 Place text above the dimension line DIMTDEC 2 Tolerance decimal places DIMTFAC 1.0000 Tolerance text height scaling factor DIMTIH Off Text inside extensions is horizontal DIMTIX Off Place text inside extensions DIMTM 0.0000 Minus tolerance DIMTMOVE 2 Text movement DIMTOFL Off Force line inside extension lines DIMTOH Off Text outside horizontal DIMTOL Off Tolerance dimensioning DIMTOLJ 1 Tolerance vertical justification DIMTP 0.0000 Plus tolerance DIMTSZ 0.0000 Tick size DIMTVP 0.0000 Text vertical position DIMTXSTY STANDARD Text style DIMTXT 2.5000 Text height DIMTZIN 0 Tolerance zero suppression DIMUPT Off User positioned text DIMZIN 8 Zero suppression And then include in my code: (vl-cmdf "-dimstyle" "Save" "My_Dimstyle") But as I say, I have never tried myself, and so I would not know if this would work or not... 2) I personally do not think it is possible to lock a dimstyle, but others may prove me wrong. Quote
