Copy line length and paste it in a block attribute
(I assume stepping through with entnext could work to find others?).
I am sorry to say it does not work also expect for 3Dpolyline .
Try this Vanilla code to get the length of Straight LWpolyline ONLY .
(defun length_LW (e / lst d)
 ;;     Author : Tharwat Al Shoufi        ;;
 ;; To get the length of Straight LWpolyline     ;;
 (foreach x (entget e)
   (if (eq (car x) 10)
     (setq lst (cons (cdr x) lst))
 (setq d 0.)
 (while (and lst
             (not (eq (length lst) 1))
   (setq d   (+ d (distance (car lst) (cadr lst)))
         lst (cdr lst)
 d
Usage ...
(length_LW (car (entsel "\n Select LWpolyline :")))
  • Replies 25
  • CheSyn
    8
  • cmscardoso
    8
  • Tharwat
    6
  • GP_
    2
@CheSyn
(distance l1 l2) does not work with polylines, lines only.
Please see the revised code on this page:
   (if
       (= "LINE" (cdr (assoc 0 lx)) )
       (setq l1 (cdr (assoc 10 lx))
               l2 (cdr (assoc 11 lx))
               ld (rtos (distance l1 l2) 2 0)
               l2 (cdr (assoc 10 (reverse lx)))
I used this to differentiate between lines and polylines (only works for a polyline with 2 vertices).
Well, just to make things a bit more difficult/interesting :roll: is it possible to, in the same drawing, and with an addtional block do this:
a) get length of the line
b) insert length of the line in the METROS_TOTAL attribute of the IDENTIFICACAO_CABO block
c) In another block (CARIMBO-DTE) that has the same insert point of the line and IDENTIFICACAO_CABO block, check one attribute (namely TIPO_ACESSO), and check if it has an "A", an "S" or na "F" and, according to that attribute, fill as follow:
.:. If it has an "A" - Additionally to put total length of the line in the attribute METROS_TOTAL of the IDENTIFICACAO_CABO block, insert it too in attribute METROS_AEREO
.:. If it has an "S" - Additionally to put total length of the line in the attribute METROS_TOTAL of the IDENTIFICACAO_CABO block, insert it too in attribute METROS_CONDUTA
.:. If it has an "F" - Additionally to put total length of the line in the attribute METROS_TOTAL of the IDENTIFICACAO_CABO block, insert it too in attribute METROS_FACHADA
And now, what i think that is the most difficult task...
In the same IDENTIFICACAO_CABO block, the text has always the same length - 02fc/01fa/21m - the first 10 digits are inserted manually, but the next 2 digits, are the length inserted in the field METROS_TOTAL. Is it possible to get that METROS_TOTAL value and insert it after the 10 digits and add a final "m" in the end. Example: XXXX/XXXX/"METROS_TOTAL VALUE"m
Basically (or not lol), like the attached drawing
:twisted::twisted::P
Thanks in advanceLineLength2BlockAttribute.dxf
Interesting, I'll study the code you posted. :)
Simply to get LINE,POLYLINE,LWPOLYLINE Length
  (setq s (car (entsel)))
 (setq d (vlax-curve-getdistatparam s (vlax-curve-getendparam s)))
 (princ d)
Thanks in advance
[ATTACH]44181[/ATTACH]
Can anyone help please?
