simple as that ...
in 2014 i cannot save this bloody file as dxf...
what could be wrong with the file?!
Have you tried a -PURGE for Regapps and All and AUDIT on the file?
tried everything from -purge to exporttoautocad audit clean dng .....
actually i ve tried every trick in the book.
this one kills me
exporttoautocad did find some aec, removed them...
still does not work.
cleaned all nul objects in a drawing (and layouts too and nested) (text lines blocks...)
to no avail.
Try a zoom>all, then zoom out, select>all, then deselect anything visible and erase. Then -PURGE again.
Can you post the .dwg here?
THE FILE
Here s the file... I think it might be that layouts contain faulty elements too...
I can't even open the file so I cannot take a look at it. The format is unfamiliar to me.
It is a shame that these files for inspection cannot be uploaded into the Cloud with AutoCAD 360, and then logged-in members could access them.
ill zip it for you... 7zip is ultimate compress freeware available for years... have a look at it once, you'll love it (zip and rar compared to this are obsolete and I'd dare to say, junk).
