Microstation DGN to DWG export blockname problem.
Hello,
I have to convert 1000 or more DGN drawings to Autocad. Using the Microstation export/convert option works very wel. But the blocks getting all a diffrent name.
One block keeps the orginal name en the others get a sufflix. Like the orginal=D344A and the others D344A1 and D344A2 etc etc.
I found a lisp thats works well. Run the lisp by typing BSW, select a block with the suffix en second the block with the orginal name. But now i have to do it manual drawing after drawing.
How can i use it in a script?
Like:
BSW
D344A1
D344A
_ATTSYNC
NAME
D344A
Thanks,
PMXCad
BSW.LSP
27B05_26_1ssd2-Default.dwg
