Bounding Box for Selection Set
What would be the best way to get a bounding box for a selection set in VBA?
Google found a LISP routine that can do it, but it has been years since I have used LISP
I was thinking someone here might be easily able to convert this small LISP routine to VBA for me
(defun LM:SSBoundingBox ( ss / i l1 l2 ll ur )
   (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'll 'ur)
   (setq
     l1 (cons (vlax-safearray->list ll) l1)
     l2 (cons (vlax-safearray->list ur) l2)
  (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list l1 l2))
i guess now that i think about it - it's probably not all that hard to just iterate thru each item in the selection set and track the min and max x and y coords... i guess i was just thinking that autocad would have this built in... guess not
ok, so yeah, i feel like an idiot for even asking this question now
here's the solution for those of you who wondered
Public Sub GetSSBoundingBox(ss As AcadSelectionSet, ptMin As Variant, ptMax As Variant)
 Dim entItem As AcadEntity
 Dim ptImin As Variant
 Dim ptImax As Variant
 Const X = 0
 Const Y = 1
 ss(0).GetBoundingBox ptMin, ptMax
 For Each entItem In ss
   entItem.GetBoundingBox ptImin, ptImax
   If ptImin(X) < ptMin(X) Then ptMin(X) = ptImin(X)
   If ptImin(Y) < ptMin(Y) Then ptMin(Y) = ptImin(Y)
   If ptImax(X) > ptMax(X) Then ptMax(X) = ptImax(X)
   If ptImax(Y) > ptMax(Y) Then ptMax(Y) = ptImax(Y)
 Next
End Sub
and here is how to call the function
Public Sub FlipTest()
 Dim ssFlip As AcadSelectionSet
 Dim pt1 As Variant
 Dim pt2 As Variant
 ' get selection set from user
 Set ssFlip = ThisDrawing.SelectionSets.Add("flip")
 ssFlip.SelectOnScreen
 ' get bounding box of selection set
 GetSSBoundingBox ssFlip, pt1, pt2
 ' draw a line from point to point
 ThisDrawing.ModelSpace.AddLine pt1, pt2
 ssFlip.Delete
End Sub
  • 3 years later...
your code is awesome
is there any way to pass this pt1 & pt2 to plot (window) for printing
selvamani the code does this look at ptimin ptimax . You can pass these to a plot window sub and say use Fit. There is lots of plot code here mainly lisp but I am sure you can find a VBA version, if thats what you want. https://forums.autodesk.com/t5/autocad-forum/plotting-in-a-vba-script/td-p/3249378
abraxus a check for which space your in may be a good idea. Tested in a layout and drew a line in model space. Nice code though can see lots of use like plotting.
Edited by BIGAL
thanks BIGAL
i need to find specific block which is used multiple times in a cad and and change its attributes values one by one through vba
any help on this please
selvamani do a search here for attribute & vba lots of posted examples.
this points iam getting from bounding box in main sub
i dont know what is happenning i got only empty window as layout but actually points given to setplotwindow is not empty plese help on this code for your reference
Sub Example_SetWindowToPlot(point1 As Variant, point2 As Variant)
' This example allows the user to define an area in the current layout
' and displays a plot preview of the defined area.
' * Note: You have to exit the
' plot preview before the VBA example will stop and control will be returned
AppActivate ThisDrawing.Application.Caption
' Dim point1 As Variant, point2 As Variant
' Get first point in window
'point1 = ThisDrawing.Utility.GetPoint(, "Click the lower-left of the window to plot.")
ReDim Preserve point1(0 To 1) ' Change this to a 2D array by removing the Z position
' Get second point in window
'point2 = ThisDrawing.Utility.GetPoint(, "Click the upper-right of the window to plot.")
ReDim Preserve point2(0 To 1) ' Change this to a 2D array by removing the Z position
' Send information about window to current layout
ThisDrawing.ActiveLayout.SetWindowToPlot point1, point2
ThisDrawing.Plot.DisplayPlotPreview acFullPreview
' Read back window information
ThisDrawing.ActiveLayout.GetWindowToPlot point1, point2
MsgBox "Press any key to plot the following window:" & vbCrLf & vbCrLf & _
"Lower Left: " & point1(0) & ", " & point1(1) & vbCrLf & _
"Upper Right: " & point2(0) & ", " & point2(1)
' Be sure to plot a view, not some other plot style
ThisDrawing.ActiveLayout.PlotType = acWindow
' Send Plot To Window
ThisDrawing.ActiveLayout.ConfigName = "DWG to PDF.pc3"
End Sub
  • 2 years later...
How do you get the dimensions length and width of the bounding box. Also if the shape is rotated how could i make that work  something like  LM:minboundingbox.
I'm working on a macro to get a shape max and min dimensions to export to exel file. thinking it would be easier in vba then Lisp
The length and width can be calculated by subtracting the minimum X/Y values from the maximum X/Y values. If it is rotated then you would need to rotate the objects back to a 0 rotation before getting the bounding box. You can do this with temporary objects you create by making a copy of them first, and then deleting them after the calculations have been made. The way a bounding box works is that it has to be based on 90 degree values from the WCS.
Try UCS OB then do bounding box. Checked a rectang same ht etc.
Edited by BIGAL
