Is there a command to lock and unlock all view ports at once.
If not can somebody develop a LISP code.Please.
Macro Lock all
_LA;LO;*;;
& Unlock all
_LA;U;*;;
OOPS why did I read that as layers
Edited by steven-g
A quickly written code
(Defun c:vplk ()
(setq d (ssget "_x" '((0 . "VIEWPORT"))))
 	(vplock d T)(princ))
(Defun c:vpun ()
 	(vplock d nil)
(Defun vplock (sel flg)
	(setq mode (if flg  :vlax-true :vlax-false))
(repeat (setq i (sslength sel))
	  (vlax-put-property (vlax-ename->vla-object (ssname sel (Setq i (1- i))))
	    'DisplayLocked mode)
 	(princ (strcat "\nViewports " (if flg "" "Un" )  "locked"))(princ)
(vl-load-com)
Another ...
(defun c:Test(/ User_request ss adoc layers lay )
 ;;ViewPorts Lock and Unlock
 ::Ganesh Shetty
 ;;2013
   (vl-load-com)
(initget "Lock Unlock")
(if
    (and
	    (setq User_request (getkword "\nViewports want to [Lock / Unlock]:"))
	    (setq ss (ssget "X" '((0 . "VIEWPORT"))))
	    (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	    (setq layers (vla-get-layers adoc))
	    (vlax-for vp (setq ss (vla-get-activeselectionset adoc))
	       (setq lay (vla-Item layers (vla-get-layer vp)))
	       (if (= (vlax-get-property lay "lock") :vlax-True)
		   (vlax-Put-Property lay "lock" :Vlax-false)
	       (if (= user_request "Lock")
		        (if (= (vlax-get-property vp 'Displaylocked) :vlax-false)
			    (vlax-put-Property vp 'DisplayLocked :vlax-True)
		        (if (= (vlax-get-property vp 'Displaylocked) :vlax-true)
			    (vlax-put-property vp 'Displaylocked :vlax-false)
                 (vla-delete ss)
Edited by gS7
Code revised
There are some examples of how to do it with a macro on a tool palette here:http://www.cad-notes.com/2011/12/eleven-killer-tool-palette-macros-for-working-with-autocad-viewports/
I hope that the OP has the viewports on Unlocked layers :D
Someone needs to localize his variables as well . ;)
Thanks gentlemen, both codes are working nicely.
