land desktop problem how to fix it
open my dwg. file in land alighnments are not worked (save as 2004 also same problem)
error message below
Autodesk Land Desktop cannot initialize because this
drawing contains objects from a newer version.
Refer to the readme file for more information on this issue.
If you cannot install the trial of C3D 2014, try to partially convert that drawing to your 2010 format, by means of Autodesk Trueview, sir.
I don't suppose you can ask someone to save it down to your version?
Or use trueview to save it down to make it compatible?
Edited by PotGuy
Just saw Emigrato's post. DOH!
