gafemon Posted October 8, 2013 Posted October 8, 2013 Hi all, I need to constantly print PDF to email to client and to print directly from printer for our project leader to review. But whenever I print by "Adobe PDF" the color is lighter than if I just print from our office printer. I setup plot style by making different % of screening on each color and by adjusting line weight on drawing layer. What am I doing wrong? Quote
SLW210 Posted October 8, 2013 Posted October 8, 2013 Did you try the DWG to PDF.pc3? Can you post your plot settings and a PDF that shows this? Can you post a .dwg? Quote
gafemon Posted October 8, 2013 Author Posted October 8, 2013 I'm using background mask on the text, if I save using DWG to PDF, it will show black block on the text. that's why i use Adobe PDF. I can not attach any file for some reason. what can i do? Quote
Mike_Taylor Posted October 8, 2013 Posted October 8, 2013 What colour are you setting your background mask to? Sometimes when setting it I have noticed that pen styles are ignored and your mask will print black (only happens with text). Try setting the background mask to same colour as background (it is a selection box). Quote
gafemon Posted October 8, 2013 Author Posted October 8, 2013 Hi Mike, I do use background color. it print black.... :/ Quote
SLW210 Posted October 8, 2013 Posted October 8, 2013 To attach files select "Go Advanced" at lower right of reply box, then select "Manage Attachments" browse to the file and select upload. Quote
