I was not aware of automatic dimensioning in AutoCAD 2011.
Can you please explain further?
Because Quick dimension only support the horizontal or vertical direction dimensioning (One from two at a particular time). So the whole object's dimensioning can not be done in one time........ I am unaware to VBA.... Can you please elaborate it for me...............I will be very thankful to you.....
The video links to a bit of add on software, which looks great on you tube.
I downloaded the free trial about a year ago, because it looked so great.
I found that, for the work I do, it was not as great as I had hoped,
or rather as it appeared on youtube.
I imagine that you can still download it for free trial, and
judge for yourself.
Did you read the thread? VBA is a programming language.
Did you download and try Fixo's auto dimensioning lisp routine?
If you had a program when you used 2011, then either you need to reinstall it or it doesn't work with 2012.
Did you check and see if the program was reinstalled?
