GlnGrnr Posted October 10, 2013 Posted October 10, 2013 Okay so here is my problem, i have a client drawing that has 22 xrefs and i need to change the color of each xref (all layers included in xref) into a different color. so I have been manually going into the layer manager and then highlighting all the layers on the xref and changing its color to a set colour and so on till i end up with, xref 1 all layers = red, xref 2 all layers = blue etc.. is it possible to create a lisp to do this for me, i have looked through the forums and found several lisps that can change the layers of a selected xref but not in the same method i.e. by name any help would be great? regards Glen Quote
Tharwat Posted October 10, 2013 Posted October 10, 2013 Try something like this . (vl-load-com) (defun ChangeXrefLayerColor (color XrefName / doc) (vlax-for x (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (if (wcmatch (strcase (vla-get-name x)) (strcat XrefName "|*")) (vla-put-color x color) ) ) (vla-regen doc acAllViewports) (princ) ) Quote
GlnGrnr Posted October 10, 2013 Author Posted October 10, 2013 Try something like this . (vl-load-com) (defun ChangeXrefLayerColor (color XrefName) (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) (if (wcmatch (strcase (vla-get-name x)) (strcat XrefName "|*")) (vla-put-color x color) ) ) (princ) ) how do i get this to run, i caved it as a.lsp and apploaded it but when i type the command (ChangeXrefLayerColor) it does not run thanks for such a quick response Tharwat Quote
Tharwat Posted October 10, 2013 Posted October 10, 2013 Example of usage ... *- Number 2 indicates to color number 1 = red *- "BASEMENT represents the Xref name and it supposed to be in Capital letters . (ChangeXrefLayerColor 1 "BASEMENT") NOTE : I updated the codes , so consider the new modified one to test . Quote
GlnGrnr Posted October 10, 2013 Author Posted October 10, 2013 I must be missing something as I am getting a syntax error. here is the code i have changed slightly (vl-load-com) (defun ChangeXrefLayerColor (1 "0618_AC" / doc) (vlax-for x (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (if (wcmatch (strcase (vla-get-name x)) (strcat XrefName "|*")) (vla-put-color x color) ) ) (vla-regen doc acAllViewports) (princ) ) Quote
Tharwat Posted October 10, 2013 Posted October 10, 2013 Just load the codes that I posted in my first post then copy and paste this in the command line . (ChangeXrefLayerColor 1 "0618_AC") Quote
alanjt Posted October 10, 2013 Posted October 10, 2013 (edited) This could be quickly accomplished from the commandline version of LAYER (aka -Layer or -LA). eg. Command: LA -LAYER Current layer: "0" Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Fre eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: C New color [Truecolor/COlorbook] : 6 Enter name list of layer(s) for color 6 (magenta) <0>: *|* No matching layer names found. Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Fre eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Take note that "*|*" as your layer name filter will selected only xref layers. Now, I do have this routine that I use from time-to-time... (defun c:XCC (/ xrefs lst color name) ;; XRef Color Change (change color of objects in selected XRef(s) ;; Required subroutines: AT:ListSelect ;; Alan J. Thompson, 02.09.11 / 2013.10.10 (vlax-for x (vla-get-blocks (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (if (eq (vla-get-isXRef x) :vlax-true) (setq xrefs (cons (strcase (strcat (vla-get-name x) "|*")) xrefs)) ) ) (cond ((not (setq xrefs (vl-sort xrefs '<))) (alert "No XRefs in drawing")) ((and (setq lst (AT:ListSelect "Select XRef(s) to change: " "" 10 10 "true" xrefs)) (setq color (acad_colordlg 1 nil)) ) (vlax-for x (vla-get-layers *AcadDoc*) (setq name (strcase (vla-get-name x))) (if (vl-some (function (lambda (xref) (wcmatch name xref))) lst) (vla-put-color x color) ) ) (vla-regen *AcadDoc* acAllViewports) ) ) (princ) ) (vl-load-com) (defun AT:ListSelect (title label height width multi lst / fn fo d item f) ;; List Select Dialog (Temp DCL list box selection, based on provided list) ;; title - list box title ;; label - label for list box ;; height - height of box ;; width - width of box ;; multi - selection method ["true": multiple, "false": single] ;; lst - list of strings to place in list box ;; Alan J. Thompson, 09.23.08 / 05.17.10 (rewrite) (setq fo (open (setq fn (vl-filename-mktemp "" "" ".dcl")) "w")) (foreach x (list (strcat "list_select : dialog { label = \"" title "\"; spacer;") (strcat ": list_box { label = \"" label "\";" "key = \"lst\";") (strcat "allow_accept = true; height = " (vl-princ-to-string height) ";") (strcat "width = " (vl-princ-to-string width) ";") (strcat "multiple_select = " multi "; } spacer; ok_cancel; }") ) (write-line x fo) ) (close fo) (new_dialog "list_select" (setq d (load_dialog fn))) (start_list "lst") (mapcar (function add_list) lst) (end_list) (setq item (set_tile "lst" "0")) (action_tile "lst" "(setq item $value)") (setq f (start_dialog)) (unload_dialog d) (vl-file-delete fn) (if (= f 1) ((lambda (s / i s l) (while (setq i (vl-string-search " " s)) (setq l (cons (nth (atoi (substr s 1 i)) lst) l)) (setq s (substr s (+ 2 i))) ) (reverse (cons (nth (atoi s) lst) l)) ) item ) ) ) Edited October 10, 2013 by alanjt Quote
Tharwat Posted October 10, 2013 Posted October 10, 2013 Nice work Alan , a line of codes to regen afterall would be perfect Quote
pBe Posted October 10, 2013 Posted October 10, 2013 too slow (defun c:xcolorsequence (/ a col xrs) (setq col 0 xrs nil ) (while (setq a (tblnext "block" (not a))) (if (assoc 1 a) (setq xrs (cons (cdr (assoc 2 a)) xrs)) ) ) (foreach itm (acad_strlsort xrs) (command "_layer" "_color" (setq col (1+ col)) (strcat itm "|*") "" ) ) (princ) ) Quote
alanjt Posted October 10, 2013 Posted October 10, 2013 Nice work Alan , a line of codes to regen afterall would be perfect Done and done. Quote
Tharwat Posted October 10, 2013 Posted October 10, 2013 too slow A few minutes late better than not coming . Welcome back pBe Quote
pBe Posted October 10, 2013 Posted October 10, 2013 A few minutes late better than not coming . Indeed Welcome back pBe Thank you tharwat, Its nice to be back Quote
GlnGrnr Posted October 10, 2013 Author Posted October 10, 2013 Hi Alanjt, thanks for your help but that script does not seem to work on mine. also i woudl have to select each xref in turn to change the color, what i would like to do is run one script to change all xrefs to certain colors in one go. Tharwat, that works beautifully, now my question wil be how can i get this to run as a single line executable ( i.e. defun C:rainbow xrefs (etc..) against all xrefs. so for example if i run this code below it changes it all in one run, which is great but how can i change the drawing name (0618) to change depending on the drawing i have open i tired to use the wildcard (*_AC) for example but that did not work (vl-load-com) (defun ChangeXrefLayerColor (color XrefName / doc) (vlax-for x (vla-get-layers (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (if (wcmatch (strcase (vla-get-name x)) (strcat XrefName "|*")) (vla-put-color x color) ) ) (vla-regen doc acAllViewports) (princ) ) (ChangeXrefLayerColor 1 "0618__AC") (ChangeXrefLayerColor 2 "0618__BM") (ChangeXrefLayerColor 3 "0618__CL") (ChangeXrefLayerColor 4 "0618__EC") (ChangeXrefLayerColor 5 "0618__FE") (ChangeXrefLayerColor 6 "0618__FL") (ChangeXrefLayerColor 7 "0618__FP") (ChangeXrefLayerColor 11 "0618__GC") (ChangeXrefLayerColor 41 "0618__HD") (ChangeXrefLayerColor 71 "0618__HO") (ChangeXrefLayerColor 91 "0618__HW") (ChangeXrefLayerColor 121 "0618__MW") (ChangeXrefLayerColor 151 "0618__PA") (ChangeXrefLayerColor 171 "0618__RE") (ChangeXrefLayerColor 191 "0618__RP") (ChangeXrefLayerColor 211 "0618__SL") (ChangeXrefLayerColor 241 "0618__TL") (ChangeXrefLayerColor 222 "0618__ZA") (ChangeXrefLayerColor 144 "0618__ZB") (ChangeXrefLayerColor 30 "0618__ZC") Quote
pBe Posted October 10, 2013 Posted October 10, 2013 Well now, if you have a specific xref-names and corresponding color, we can utilize that list to change the colors in one go. Play around with the code i posted using your list, pretty sure you'll get it. Quote
alanjt Posted October 10, 2013 Posted October 10, 2013 Untested: (defun _xrefLayerColorChange (xrefNameColorList) ((lambda (lst / name color) (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))) (if (setq name (strcase (vla-get-name layer)) color (vl-some (function (lambda (x) (if (wcmatch name (car x)) (cdr x) ) ) ) lst ) ) (vla-put-color layer color) ) ) ) (mapcar (function (lambda (x) (cons (strcat (strcase (car x)) "|*") (cdr x)))) xrefNameColorList ) ) ) (_xrefLayerColorChange '( ("0618__AC" . 1) ("0618__BM" . 2) ("0618__CL" . 3) ("0618__EC" . 4) ("0618__FE" . 5) ("0618__FL" . 6) ("0618__FP" . 7) ("0618__GC" . 11) ("0618__HD" . 41) ("0618__HO" . 71) ("0618__HW" . 91) ("0618__MW" . 121) ("0618__PA" . 151) ("0618__RE" . 171) ("0618__RP" . 191) ("0618__SL" . 211) ("0618__TL" . 241) ("0618__ZA" . 222) ("0618__ZB" . 144) ("0618__ZC" . 30) ) ) Quote
SLW210 Posted October 10, 2013 Posted October 10, 2013 Please read the Code posting guidelines and edit your Codes to include Code Tags. Quote
GlnGrnr Posted October 10, 2013 Author Posted October 10, 2013 Trouble is the xref name will chage for every drawing I have to review so while this list is 0618 the next will be 0619 etc. etc.. and i have 1715 drawings Quote
alanjt Posted October 10, 2013 Posted October 10, 2013 Trouble is the xref name will chage for every drawing I have to review so while this list is 0618 the next will be 0619 etc. etc.. and i have 1715 drawings Are the xref names (0619, 0618) determined by the corresponding drawing name? Quote
GlnGrnr Posted October 10, 2013 Author Posted October 10, 2013 Hi Alanjt they are determined by the xref drawing name yes. the only true constistency for them is the suffix they will always be (_AC,_BM etc...) but the number code can change Quote
Lee Mac Posted October 10, 2013 Posted October 10, 2013 Are the suffixes consistent? If so, perhaps something like: ([color=BLUE]defun[/color] c:xc ( [color=BLUE]/[/color] n ) ([color=BLUE]vlax-for[/color] l ([color=BLUE]vla-get-layers[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))) ([color=BLUE]if[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]setq[/color] n ([color=BLUE]strcase[/color] ([color=BLUE]vla-get-name[/color] l))) [color=MAROON]"*|*"[/color]) ([color=BLUE]vl-some[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]if[/color] ([color=BLUE]wcmatch[/color] n ([color=BLUE]car[/color] x)) ([color=BLUE]progn[/color] ([color=BLUE]vla-put-color[/color] l ([color=BLUE]cdr[/color] x)) [color=BLUE]t[/color]) ) ) '( ([color=MAROON]"*AC*"[/color] . 001) ([color=MAROON]"*BM*"[/color] . 002) ([color=MAROON]"*CL*"[/color] . 003) ([color=MAROON]"*EC*"[/color] . 004) ([color=MAROON]"*FE*"[/color] . 005) ([color=MAROON]"*FL*"[/color] . 006) ([color=MAROON]"*FP*"[/color] . 007) ([color=MAROON]"*GC*"[/color] . 011) ([color=MAROON]"*HD*"[/color] . 041) ([color=MAROON]"*HO*"[/color] . 071) ([color=MAROON]"*HW*"[/color] . 091) ([color=MAROON]"*MW*"[/color] . 121) ([color=MAROON]"*PA*"[/color] . 151) ([color=MAROON]"*RE*"[/color] . 171) ([color=MAROON]"*RP*"[/color] . 191) ([color=MAROON]"*SL*"[/color] . 211) ([color=MAROON]"*TL*"[/color] . 241) ([color=MAROON]"*ZA*"[/color] . 222) ([color=MAROON]"*ZB*"[/color] . 144) ([color=MAROON]"*ZC*"[/color] . 030) ) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) EDIT: I see you just answered that question... Quote
