Hi Lee Mac
that looks great but when i load the lisp through appload and then type xc into the comman line it does not do anything? am I loading it wrong?
  • Replies 29
  • GlnGrnr
    10
  • Tharwat
    7
  • alanjt
    4
  • pBe
    4
I see no error in the code (unless I have missed something) - I can only assume that matches are found with your layer names...
i think you may be right, i dont think it has found the xrefs loaded into the drawing as a match. could it be the wildcard (*)
Yes thats right | i am ot sure why it wont run as i cannot see the issue either, i have even tried renaming the xref list to match that of the drawing but still no joy, thanks for all your help so far means alot with a project this size
Still using command: Layer
(defun c:xcs (/ a col xrs nme p col)
 (setvar 'cmdecho 0)
 (setq lst	'(("AC" . 1)
  ("_BM" . 2)
  ("_CL" . 3)
  ("_EC" . 4)
  ("_FE" . 5)
  ("_FL" . 6)
  ("_FP" . 7)
  ("_GC" . 11)
  ("_HD" . 41)
  ("_HO" . 71)
  ("_HW" . 91)
  ("_MW" . 121)
  ("_PA" . 151)
  ("_RE" . 171)
  ("_RP" . 191)
  ("_SL" . 211)
  ("_TL" . 241)
  ("_ZA" . 222)
  ("_ZB" . 144)
  ("_ZC" . 30)
 (while (setq a (tblnext "block" (not a)))
   (if	(and
  (setq nme (cdr (assoc 1 a)))
  (setq	p (vl-string-position
	    95
	    (setq sf (vl-filename-base nme))
	    nil
	    t
  (setq col (assoc (substr sf (1+ p)) lst))
     (command "_layer"
       "_color"
       (cdr col)
       (strcat sf "|*")
Try this UNTESTED codes and let me know .
(vl-load-com)
(defun c:Test (/ l doc)
 (setq l '((1 "0618__AC")
           (2 "0618__BM")
           (3 "0618__CL")
           (4 "0618__EC")
           (5 "0618__FE")
           (6 "0618__FL")
           (7 "0618__FP")
           (11 "0618__GC")
           (41 "0618__HD")
           (71 "0618__HO")
           (91 "0618__HW")
           (121 "0618__MW")
           (151 "0618__PA")
           (171 "0618__RE")
           (191 "0618__RP")
           (211 "0618__SL")
           (241 "0618__TL")
           (222 "0618__ZA")
           (144 "0618__ZB")
           (30 "0618__ZC")
 (vlax-for x
           (vla-get-layers
             (setq doc (vla-get-activedocument (vlax-get-acad-object)))
   (foreach xr l
     (if (wcmatch (strcase (vla-get-name x)) (strcat (cadr xr) "|*"))
       (vla-put-color x (car xr))
 (vla-regen doc acAllViewports)
pBe, code works fantastic, thankyou everyone for your help on this you have just saved me approximately 35 days of work load. :o) i have been trying to learn lsp but have been so over loaded with work I have nto got much further than the tutorials. once again thanks for your help
