Hi , I try to bind a XREF drawing and give me this error
fatal error unhandled e06d7363h exception fd2caa7dh
Any ideas. How can i skip this problem ?
What have you tried so far? Did you try to clean up the XREF file like running purge and audit for starters?
So you have tried nothing? Did you even google the error?
What did you find that was close? Have you tried cleaning up the XREF, yet?
i purge the drawing and gives me a new error
FATAL ERROR Unhandled e06d7363h Exception at fdb6aa7dh
You've posted three times since I gave you a couple of suggestions. I can't help those who don't help themselves.
I can not understand you !!:?
I'm sorry but I cannot help you at this time.
Try following these steps on both the file you are working in and the file you are trying to Bind.
Process to remove corruption:
  1. Open file
  2. From the command prompt type: -PURGE (then select "R" for Reggapps, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  3. From the command prompt type: -PURGE (then select "A" for All, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  4. From the command prompt type: AUDIT (then select "Y" for Yes, then hit [ENTER])
  5. Save the drawing file
  6. Open a new blank drawing file
  7. From the command prompt type: INSERT (then select the drawing file affected that you just use the above process on, make sure it is set to insert at 0,0,0 and explode upon insertion in the check box)
  8. From the command prompt type: -PURGE (then select "R" for Reggapps, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  9. From the command prompt type: -PURGE (then select "A" for All, then hit [ENTER], then select "N" for no on running through each individual instance and then again [ENTER])
  10. From the command prompt type: AUDIT (then select "Y" for Yes, then hit [ENTER])
  11. Save the drawing file
I try them all and i still have FATAL ERROR ?:?
I have a file with 40 drawings for the same road and i have the same problem . I have this files since 1999
You still haven't answered my question. Can you Bind OTHER Xrefs in OTHER drawings?
You will have to trial and error to find the troublesome part of the drawing, AFAIK.
Can you post the drawing you are trying to Bind?
What you are saying doesn't make sense. There is a total of 12 XREFs in Hydrpo1a. Which one is the one that you cannot bind? You really need to provide more information in order for anyone to help you.
Edited by RobDraw
