T2L Posted November 25, 2008 Posted November 25, 2008 Can you tell me why variables D:number will not hold the value when you enter return. (if D:number (setq dia (getreal (strcat "\nEnter Nominal diameter <"(rtos D:number)">: "))) (setq dia (getreal "\nEnter Nominal diameter: ")) ) (if (/= dia "") (setq D:number dia) ) I've got a message that said Error: Bad argument type: numberp: nil Because of numberp my guess is the rtos. But how can I correct this? Thanks. Quote
profcad Posted November 25, 2008 Posted November 25, 2008 When you press enter, DIA is nil not an empty string "". try (if (null dia) (setq D:number dia) ) Also, is d:number a global or local variable? Quote
T2L Posted November 25, 2008 Author Posted November 25, 2008 It is a local variable. I'll try your suggestion. Post later. Thanks Quote
T2L Posted November 25, 2008 Author Posted November 25, 2008 Suggestion does not work. BTW my fault, d:number should be global and dia local. Quote
profcad Posted November 25, 2008 Posted November 25, 2008 The problem is in your if statement see below... (defun c:test ( / dia ) (if D:number (setq dia (getreal (strcat "\nEnter Nominal diameter <"(rtos D:number)">: "))) (setq dia (getreal "\nEnter Nominal diameter: ")) ) (if dia (setq D:number dia) ) ) You want to change the value of d:number if DIA has a value (non-nil). Quote
Lee Mac Posted November 25, 2008 Posted November 25, 2008 I believe this contains what you are after (defun c:tktag2set (/ tsize tcircr) (if (not (getenv "tag:tsize")) (setenv "tag:tsize" (rtos (getvar "TEXTSIZE"))) ) ; end if (if (not (getenv "tag:tcircr")) (setenv "tag:tcircr" "4.2") ) ; end if (princ (strcat "\nCurrent Settings:" "\n\tText Height: " (getenv "tag:tsize") ",\tText Circle Radius @ 1:1: " (getenv "tag:tcircr") ) ; end strcat ) ; end princ (if (setq tsize (getreal (strcat "\nSpecify Text Height <" (getenv "tag:tsize") ">: "))) (setenv "tag:tsize" (rtos tsize)) ) ; end if (if (setq tcircr (getreal (strcat "\nSpecify Text Circle Radius @ 1:1 <" (getenv "tag:tcircr") ">: "))) (setenv "tag:tcircr" (rtos tcircr)) ) ; end if (princ "\nBase Variables Set.") (princ) ) ; end program Quote
Lee Mac Posted November 26, 2008 Posted November 26, 2008 For example: (defun c:test (/ dia) (or (getenv "D:number") (setenv "D:number" "5")) (if (setq dia (getreal (strcat "\nEnter Nominal Diameter <" (getenv "D:number") ">: "))) (setenv "D:number" (rtos dia)) ) ; end if (alert (strcat (getenv "D:number") " is the value of the global Variable.")) (princ) ) Quote
