cadmando2 Posted November 25, 2008 Posted November 25, 2008 Hay all, How can I get my custom toolbars & Icons I created in 2004 AutoCad into 2008? Can they be imported in to 2008? Quote
GhostRider Posted November 25, 2008 Posted November 25, 2008 Using the migrate from the installation disk is the easiest way, you can transfer things manually using the CUI also. the help file explains it all pretty well. You can migrate custom MNU or MNS files from earlier releases using the Customize User Interface (CUI) Editor. The program transfers all of the data in the MNU or MNS file to a CUI file without modifying the original menu file. The new CUI file is an XML-based file that has the same name as your original menu file, but with a .cui extension. You can also transfer customization information between files. For example, you can transfer toolbars from a partial CUI file to the main CUI file so that the program can display the toolbar information. NoteAll elements can be transferred between two CUI files with the exception of the property settings defined under the Quick Properties and Rollover Tooltips nodes. Quote
