I wanted to write a lisp to set-up a pc for a new user. I wanted to copy the acad.lsp to the autocad support folder with this code:
(vl-file-copy "S:\\RSH CAD Core\\ACAD File\\acad.LSP" "C:\\program files\\autodesk\\autocad 2012 - english\\support\\acad.LSP" )
But that doesn't work. I can't copy anything into that location. I have tried using the shell command and that doesn't work either. I use the acad.lsp file to load our cadcore routine using this:
(load (findfile "CADCore.LSP"))[code]
[/code]
Help please
Edited by WPerciful
Try This way
(vl-file-copy "S:/RSH CAD Core/ACAD File/acad.LSP" (strcat "C:/Documents and Settings/" (getvar "loginname") "/My Documents/acad.LSP"))
I’m sorry I meant to say that I am trying to copy our acad.lsp file from the network location to AutoCAD support folder.
But the code doesn't work:
WPerciful I Don't Think You Can copy Acad.Lsp to Autocad CAD Support Folder ,Try to make ACADDOC.lsp and copy to support folder
That didn't work either. But thank you for your help.
A few questions:
  • Do you have read permissions for the source directory?
  • Do you have write permissions for the destination directory?
  • Can AutoCAD locate the source file on the network, i.e. does
    (findfile "S:\\RSH CAD Core\\ACAD File\\acad.LSP")
    Return the filepath or nil?
  • Does the destination directory definitely exist on the system? i.e. does
    (findfile "C:\\program files\\autodesk\\autocad 2012 - english\\support")
I have permission for the source directory.
I can locate the source file on the network.
If I manually copy the file over to the autocad support folder I get a “Destination Folder Access Denied” dialog box.
If that is what is stopping it, how do I fix it?
That would be the problem -
You will need to get write permissions (administrator privileges) for the destination directory.
That was it. Thank you very much. :) :) :)
On a side note I use your website as a reference aid a lot and it’s been a big help. The Error Message section is awesome . Would you happen to know what kind of error “bad argument type: streamp nil” is?
Excellent - you're welcome!
Thank you - I'm delighted that you find it useful.
The error: 'bad argument type: streamp nil' means you have passed a function requiring a file descriptor argument a nil value, for example, passing a null file descriptor argument to the close function:
_$ (close nil)
; error: bad argument type: streamp nil
I shall update the troubleshooter to include this error message.
