Brad V Posted October 23, 2013 Posted October 23, 2013 I am getting back into Civil design after an extended layoff and I'm learning Civil 3d on the job/ also on my own. Hopefully that will explain what may be a very simple question. I just created a proposed surface using a point group. When I started labeling the contours I noticed they are 1 foot lower than they should be. I checked some spot elevations and I found this consistent across the site. Is there a setting that would have caused the surface to be created 1 foot lower than the proposed points? Thanks for any help. Quote
Organic Posted October 26, 2013 Posted October 26, 2013 See http://docs.autodesk.com/CIVIL/2010/ENU/AutoCAD%20Civil%202010%20User%20Documentation/index.html?url=WS27101fef35e777f9aeffdffbf5418ea8-7f02-procedure.htm,topicNumber=d0e79853 Quote
Brad V Posted October 28, 2013 Author Posted October 28, 2013 Thanks for the response. I ended up deleting and recreating the surface, this time it was correct. My concern wasn't so much how to raise the surface but why using only the points I entered would it be created a foot too low. Oh well, live and learn. Next time I'll verify the surface is correct before I calculate my earthwork. On first glance the proposed contours looked like what I expected so I didn't label them. Quote
